Tire damage on trailer, would you drive with this?
Discussion in 'Questions From New Drivers' started by Nahbrown, Mar 13, 2024.
  1. Nahbrown
    Nahbrown Medium Load Member
    444
    2,080
    Sep 6, 2021
    Illinois (the sane part)
    It looks like someone took divot with a 9 iron out of this tire. It must have been on the bottom of the tire when I did our pretrip because I didn’t see it until our first stop. I put in a DVIR but we drove it. Why? the divot wasnt past the surface rubber, all other trailer tires were stellar and our loads were light.
    When we got back I think they replaced it.
    Just because it worked doesn’t mean I was right. Would you have had it replaced midtrip?
    Kyle G. Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    77,011
    179,786
    Aug 28, 2011
    Henderson, NV & Orient
    I wouldn't have had it replaced mid-trip.
    Hatt91, tscottme, Sons Hero and 3 others Thank this.
  4. SmallPackage
    5,702
    18,226
    Dec 20, 2019
    Marion Texas
    Nothing unsafe about that. Tread chunking. Happened from scrubbing on rough surface or railroad crossing in a tight turn. Only need to worry about it if the tread blocks pulled out at the under tread layer.
    Sons Hero, Arctic_fox, Kyle G. and 3 others Thank this.
  5. Short Fuse EOD
    2,786
    8,739
    Jul 29, 2015
    Midwest
    No, I wouldn’t replace that tire until it gets worn down more.-As far as I can tell from the pic. As it gets closer to summer fast speed and hot roads will accelerate the damage. Ground spots will grow. Until about June and as long it don’t see metal, I’d use it on the trailer.
    Sons Hero, Kyle G. and Nahbrown Thank this.
  6. Ridgeline
    22,636
    120,662
    Replace the tire as soon as you can. you get any inspection, the cop won't care what anyone thinks on a forum, he will ding you with an OOS until it is replaced. Beleive me I know.
    Nahbrown and lual Thank this.
  7. shatteredsquare
    shatteredsquare Road Train Member
    1,404
    1,836
    May 23, 2014
    middle dirt
    if you can see metal (cords) through the rubber it's OOS, if you can't see metal you're good to roll. but if you can't see metal though that hole, a hole that deep has like 2 mm of rubber left before metal, so you're good for how long before it cracks open or chunks out deeper...
    that's not a safety dangerous tire, just inspection dangerous
    Hatt91 and Arctic_fox Thank this.
  8. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,519
    2,622
    Jan 7, 2023
    Yes, it's a good idea to get it replaced, especially if you run either Tennessee or California; those states would put you OOS in a heartbeat! Imagine having to have that tire replaced at the Caltrans scale in Truckee, CA? I wouldn't want to find out just how much they charge for a tire call up there!
