I hear the chains will damage your tires, but how serious is it? Or, could it be that people are driving to fast with them?
Tire Life Using Tire Chains?
Discussion in 'Ask An Owner Operator' started by PE_T, Nov 26, 2018.
Might cause occasional small chunking, but most of the stories are exaggerated. I run chains frequently and for hours per day in the winter on a regular basis. I break chains commonly yes, but tire damage is minimal at best. Spinning because you were too lazy to chain up does cause a lot more damage to tires. That spinning tire every time it grabs any little thing like say a rock, it tears out a chunk.
Remember that most damage will be done by loose chains, and not to the tires so much as everything else those whipping chains hit. So get them as tight as you can to start with, and when safe to do so stop and retighten them if you need them on for any distance, as they loosen up while you drive. A chain with tear apart a fender, or rip off an airline or whatever it is, so fast you will be in shock how quickly it happens. Now go chain up and drive safely.Nothereoften, Ruthless, snowwy and 1 other person Thank this. -
What about tire socks? Never tried them. Sure they look easy on tires.
Do they actually work as good as chains? Less hassle putting them on? Are they even a legal substitute to chains in CO, WA, OR - where you must carry chains? -
TallJoe Thanks this.
We tried tire socks. The local distributor gave us some for free just for trying them out and reviewing them.
They didn't hold up very well under constant use on the highway. They didn't hold up at all on our off road trucks.
I didn't run them myself but our drivers said the sox didn't have the "bite" of a good set of iron chainsNothereoften, PE_T, MartinFromBC and 1 other person Thank this. -
If you chain properly you won’t damage your tires. If you just throw them on loose and don’t take the time to stop and retighten them you will damage your tires and truck and trailer when you start breaking cross links.
PE_T and MartinFromBC Thank this. -
PE_T, MartinFromBC, REO6205 and 1 other person Thank this.
Yes, if you run lots of off road (oilfield) miles. Between the rocks and the chains you seldom get a casing credit.
MartinFromBC and REO6205 Thank this.
The only thing about chains being hard on tires is when they want you to chain up, like they do sometimes in Truckee, CA and you need to run 10 - 20 miles on only wet road before you hit the snow and ice, but once you do, you feel good about having them on.
PE_T Thanks this. -
