Tire pressure on the ice road
Discussion in 'Ask An Owner Operator' started by Final Drive, Dec 1, 2019.
  1. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    Last week it got pretty hairy out there north bound on I-35
    My question is do you get more traction if you let some air out of your tires..
  3. pavrom
    pavrom Road Train Member
    3,185
    7,305
    Apr 29, 2012
    NE illinois
    ..also get some drywall screws in with the drill , no one will beat you on the ice
    PE_T, D.Tibbitt, truckdriver31 and 3 others Thank this.
  4. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    I’d think less traction .. I’ve seen signs telling people to keep tires properly inflated in winter ..
    PE_T, Final Drive and truckdriver31 Thank this.
  5. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Lower tire pressure will help to drive over deep snow, sand or loose soil. Military vehicles equipped with in cab tire pressure regulator to cross the bad places. But speed should significantly lowered to 3 -5 miles.
    For icy road low tire pressure is bad and dangerous. Lower pressure cause more tire flexing and more tire heat. Hot tire melt some ice and water works like grease. Keep tires inflated.
    PE_T, D.Tibbitt, Final Drive and 5 others Thank this.
  6. Midwest Trucker
    5,903
    21,322
    Aug 31, 2018
    Kinda like those motorbikes in Russia that race on the ice with screws in the tires. :D
    Snailexpress, PE_T and D.Tibbitt Thank this.
  7. npok
    npok Light Load Member
    160
    172
    Sep 26, 2015
    I'd think truck tires are too stiff to make much difference. We're not talking drag radials or mud tires.
    D.Tibbitt Thanks this.
  8. Final Drive
    1,573
    2,505
    Jan 21, 2015
    Thank you for your advice ....
    Midwest Trucker and D.Tibbitt Thank this.
  9. Final Drive
    1,573
    2,505
    Jan 21, 2015
    Properly inflated it is...
  10. 201
    201 Road Train Member
    12,345
    25,236
    Apr 16, 2014
    high plains colorado
    The only time I'd let air out of the tires, is if I was hopelessly stuck. Keep the tires up, and if it's that slick, pull 'er off and wait for the salt shaker.
  11. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    I never bothered with inflation.
    Roll her out onto that ice as long I could walk on it without falling truck will do fine.
    Final Drive and D.Tibbitt Thank this.
