So my truck rolls on lowpro 22.5 tires with 3:70 something rears and 18918b trans 6nz cat. Would like a few less rpm at cruising speed. What kind of rpm difference would I see with tall 24.5s?
Tire size change
Discussion in 'Trucks [ Eighteen Wheelers ]' started by lester, Mar 3, 2017.
Ohh also is the rolling resistance much different? I run fairly aggressive tires anyway
I run closed shoulder drives. 1500 rpm 72mph 18718B 3.70. I don't have a 6nz so idk about fuel mileage.. And don't really keep track of mine..
If you can get a set of the lower rolling res.11-24.5 tires it will not hurt as bad, you can look on AMBT amer. moves by truck.com web site to ck most tires roll/res. are listed over on that site.
BoxCarKidd, lester and Roger McG Thank this.
Depends how fast you want to go. Lp22.5 to 11R22.5 3-4 mph. Lp22.5 to 11R24.5 6-8mph.
Google road speed calculator and play with the numbers. -
That would be the equivalent to about 2 steps higher axle ratio.
Any negative effects from higher rolling resistance will be out wieghed by better mpg from the lower rpm while cruise.
Truck will ride a lot nicer with the tall 24.5 also. -
Swaan you may have made up my mind for me. Better ride is always a plus and lower cruising speed even better. And I've got a doner truck sitting around with 24.5 wheels
Oxbow Thanks this. -
Ive got 2 stars that are identical.
1 truck has low pro 24.5 with 3.55
2 truck has tall 24.5 with 3.70.
Same od in trans.
Both run same cruise rpm.
The truck on tall 24.5 rides a bit better.
You will have to get your speedometer adjusted for the taller tires after. Thats not hard thou. Should just be a ecm perimeter change. -
lester Thanks this.
