1. Tampa fuel Mueller
    Tampa fuel Mueller Bobtail Member
    Apr 6, 2017
    I have tire wear/ scuffing on the Inside of the Inner drive tires front axle worst . Any ideas why ? I just purchased this truck and have no knowledge of the history.
  3. Lazer
    Lazer Road Train Member
    1,830
    2,940
    Jan 22, 2017
    Both sides?
    Rideandrepair Thanks this.
  4. 401-Alex
    401-Alex Light Load Member
    258
    278
    Nov 25, 2013
    401
    Wheel bearing create a river wear or inner wear on inside of drives had it happen replaced and rotated tires and patern didn't return. Bearings could be lose or going bad. If wheel end is opened up and you see it's a 3 nut system that's probably the problem look at bearing might be good but probably are not get the races in the hub changed if any bearing damage is seen and replace the 3 nut system with a pro torque or similar system.
  5. Rideandrepair
    17,451
    56,621
    Aug 8, 2015
    I would also check the spring bushings. Rear axle Bushings usually wear first on my Freightliner. Maybe they rotated the tires before you bought it.
