Tire wear
Discussion in 'Trucks [ Eighteen Wheelers ]' started by biiqtruckin, Apr 24, 2018.
  1. biiqtruckin
    biiqtruckin Bobtail Member
    27
    Sep 20, 2017
    I have inner tire wear on my rear right inner first axle drive tire and I have inner wear on my front right axle steer tire. Steering wheel alignment is a bit off and its vibrating a bit. I have not done an alignment to this truck. Could it just need an alignment? I know I have to change that rear tire that is almost bald in the middle of it. But can I just keep that front tire that has inner tire wear only?
  3. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,334
    Feb 21, 2015
    Bement, IL
    Your life is riding on those steers. I'd look at changing them and holding off on the drive tire if money is an issue. The alignment is a must. Have them check all of your bushings in the rear too. Otherwise, your alignment will be for nothing if there are bad bushings.
    My 2 cents.
    gokiddogo Thanks this.
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Agree
    Alignment and bushings
    And do not screw around with steer tires especially. If you want to run them out a little longer you can move them to drive or trailer tires if all the same size. As long as traction isn't an issue you can get away with it.
  5. RustyBolt
    2,073
    3,334
    Feb 21, 2015
    Bement, IL
    Just realized you said that one drive is nearly bald. Find a shop that sells used tires and get one that closely matches the others as far as tread depth is concerned. But DO replace the steers.
  6. rollin coal
    rollin coal Road Train Member
    13,460
    27,456
    Mar 29, 2008
    TN
    Find a good shop locally that specializes in truck suspensions and alignments so someone that knows what they are doing will check and look it over. It should be easy to figure out in about 15 minutes to a half hour of checking all wear components. Get it fixed ASAP then put new tires on. The vibration could be anything. Bad bushings. Out of round tire. Lots of things. You won't know until everything is checked. Don't waste your time and money at a T/A, Petro, Loves or some such other shop, those places are ok for changing tires but not much else.
    Tug Toy, Big_D409, Dave_in_AZ and 2 others Thank this.
  7. Luwi67
    Luwi67 Heavy Load Member
    749
    484
    Oct 24, 2012
    Long island
    That's worn like that from over inflation.
  8. Dawnmartin
    Dawnmartin Bobtail Member
    Can any one please help me with a little problem? I have a 1996 379 peterbilt with 425 cat motor its a 35 ton wrecker and when I pick up a truck or when I am on a small incline I go to take off and my truck starts hopping and jumping out of control.any clue what could be going on here.
  9. Brandt
    Brandt Road Train Member
    4,603
    6,318
    Sep 17, 2012
  10. Brandt
    4,603
    6,318
    Sep 17, 2012
