Tires problem, need help!
Discussion in 'Ask An Owner Operator' started by Neghinam1, Aug 17, 2015.
  1. Neghinam1
    Neghinam1 Bobtail Member
    19
    Nov 2, 2014
    Guys need help, reffer 53' tire is wearing like that, what can be the problem, thank you
  3. Check on balance of tire.
    Is this a retread or original tire?
    Trailer axle alignment?
    Just a few to look into
    Neghinam1 Thanks this.
  4. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Company shop probably yanked it off the steer axle of a truck that way. Unless, the OP doesn't drive for a company. Then maybe what @peterbilt_2005 said
    Neghinam1 and peterbilt_2005 Thank this.
  5. rollin coal
    rollin coal Road Train Member
    13,326
    26,987
    Mar 29, 2008
    TN
    Might be the axle housing itself flexing. I forget what Hendrickson axle it is but there is one that is notorious for this because the axle housing is so thin it will flex going down the highway when loaded heavy causing wear similar to this. They still put them under new trailers and it's a known issue. The only remedy is to stiffen the axle by welding angle iron along it.
  6. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Also ck wheelbearing freeplay on hub by pulling hubcap off and ck. back an forth movement with end play gauge, wear on inside edge can start when bearing gets out of spec.
  7. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Hendrickson Vantraax -- easy to spot the 6" diameter axle (most axles are 5")
    maybe also loose or bad wheel bearings?
    Neghinam1 and rollin coal Thank this.
  8. mp4694330
    mp4694330 Road Train Member
    1,529
    1,459
    Aug 30, 2010
    Chicagoland
    What tire brand?
  9. 77fib77
    77fib77 Road Train Member
    10,768
    68,343
    Jul 7, 2010
    St Louis
    Are bushings bad? Does the trailer pull straight or does it favor one side more than the other?
