TMC Percentage Pay?
Discussion in 'TMC' started by Crimson Tide, Jan 29, 2014.
  1. Crimson Tide
    Crimson Tide Bobtail Member
    8
    Jan 1, 2014
    Tennessee
    What is expected by TMC month to month to stay at or move up/down on the % pay scale ?
  3. Staxx
    Staxx Bobtail Member
    26
    14
    Feb 15, 2010
    VA
    revenue to the truck,out of route,mpg are the main ones.....other variables play in,but those come with time.
    Crimson Tide Thanks this.
  4. Staxx
    26
    14
    Feb 15, 2010
    VA
    oh,pretty much be where youre supposed to be sunday night or #### close,slackers are going to get the sh.t loads.
  5. Crimson Tide
    8
    Jan 1, 2014
    Tennessee
    Your Sunday makes the rest of the week go is what I'm hearing. It was the same way with hauling cows. Better leave on Sunday if you wanted home Friday.
  6. Green Machine
    Green Machine Medium Load Member
    623
    175
    Jul 23, 2009
    I left a couple Sundays and still got home Saturday, so I stopped leaving on Sundays (when I worked for them). I would leave out early Monday morning and be at the consignee by 8:00am and would have enough time to pick up next load and run a little longer depending on circumstances.
    That being said, I still made decent checks every weekend. But, when I came home I would be pushing either my 11hr or 14hr clock. Many times I would come home with 5-20 minutes left.
  7. Crimson Tide
    8
    Jan 1, 2014
    Tennessee
    I will find out soon I guess. I leave today for Iowa.
    arichter1966 Thanks this.
  8. Aralakh
    Aralakh Bobtail Member
    37
    40
    Jan 29, 2014
    Omaha, NE
    Good luck, Crimson
  9. nb629
    nb629 Light Load Member
    213
    245
    Aug 21, 2012
    Being at consignee sunday night is key to a good week. If all goes well and you manage your clock you can spend every night at or very close to the next consignee.
    Aralakh Thanks this.
  10. Green Machine
    623
    175
    Jul 23, 2009
    Staying the night at your next consignee will save yourself a lot of time for your next day. You won't start your clock until you need to, so you aren't running down your 14-hr while untarping/unstrapping.
  11. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    The % scale is based on a point system
    You get points for:
    Truck revenue..higher revenue (more loads) = more points.
    MPG...you are compared to the rest of the fleet. Average gets average points. Getting better MPG then the average drivers gets you the most points. Average mpg target changes weekly based on everyones mpg. Higher mpg higher points.
    Out of Route Drive as close to the dispatched miles as possible. less then 4% extra miles gets the most points. Under 10% is normal for noobs. This is all averages, some trips will have 25% OOR and even perfect planning cant fix that.
    Hamat, twic, and passport Additional points will be rewarded for having each of these
    Time with TMC 1 point per year.
    Clean truck Can add points if you show up to service with a clean truck. Points will be subtracted if your in violation.
    TQM class Taking the class gives you 5 points
    Leaving on Sunday For each week-end you leave on Sunday you get an additional 5 points. (might be 5,5,4,3,3 depending on weeks in month)
    Um i think thats it. A decent driver should have enough points to maintain 28%. leaving on sunday alone can bump u up a whole % point.
