To bake the DPF or just get a new one?
Discussion in 'Ask An Owner Operator' started by Midnightrider909, Aug 16, 2021.
  1. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    The other day coming out of California I had a sensor tell me that there was too much soot in the exhaust and then a few hundred miles later it went off and has not come back on. My Volvo has 380,000 miles on it and I know it is due to get the DPF filter cleaned out but I have talked with other people that say that that doesn’t work very often and you have to replace it anyway with a new one. So should I get a new one or get this one professionally baked and hope for the best? Should I even do anything at all since the light went back off? I just don’t wanna have to worry about it coming back on and possibly getting D rated in the middle of nowhere.
    Jarhed1964 Thanks this.
  3. 86scotty
    86scotty Road Train Member
    4,525
    12,258
    Aug 27, 2017
    Appalachia
    You're at 380k and you've never serviced it? That's bad. You should do it every 200k or so, about $500 if you pull it yourself and take it to someone, which is easy.
    You may've killed yours already. Prepare thy wallet.
  4. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    How difficult are they to get a hold of right now? That would have a lot to do with the decision to me.
  5. Ridgeline
    22,463
    117,774
    I’m surprised midnight, this is dpf 101, get it clean.
  6. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    You have good luck getting yours baked clean?
    77fib77 Thanks this.
  7. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    Volvo recommended service interval is 400,000 miles.
  8. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Under ideal conditions and less than 10% idle time
  9. Ridgeline
    22,463
    117,774
    Yep, they are done with the 18 month maintenance cycle that is done on most of the trucks (not all) this includes shocks and other items that have a short life. It sounds as a waste of money but i go through a lot of sensors and don't need the headache of one more item on the list to replace.
    I have a donaldson system installed at the shop I deal with, got a hell of a deal on it, the shop owner in exchange has to do any truck I sent to him for free. Up here I use a shop that has the same system.
    Jarhed1964 and Midnightrider909 Thank this.
  10. Siinman
    Siinman Road Train Member
    5,341
    13,559
    Mar 5, 2017
    Kansas City, MO.
    Min e was baked and have had no issues with it. Not worth the money to replace it if done on service schedule.
  11. Vitkouski
    Vitkouski Light Load Member
    199
    278
    Mar 6, 2016
    DPF filter should be perfectly cleaned each time the engine make a Regen.
    If not - system is not working as good as it should and need to be repaired.
    Sensor(s), regen ingector, fuel system malfunction e.t.c.
    I think that DPF filter cleaning without fixing the whole system is a fraud!
    The filter replacement only will also not help...
