To drive or not to drive!
Discussion in 'Questions From New Drivers' started by Rambler470, Feb 1, 2016.
  1. Rambler470
    Rambler470 Bobtail Member
    44
    12
    Aug 3, 2015
    Ok question,
    You go to get your load, it's already gonna be a 12+ hr day. The mid and rear driver side turn signal/flasher is not working, would you pickup/deliver your load? Until a more convenient time to put it down for repair?
    I know the "technical" answer is probably no. But in practice what is the story?
  3. demi
    demi Medium Load Member
    471
    423
    Apr 25, 2012
    Cheyenne, WY
    brake or turn signal being out is a no go, marker lights maybe. Chances are you will make it etc, but what if?
    bottomdumpin and Rambler470 Thank this.
  4. coffee mug
    coffee mug Light Load Member
    112
    50
    Jan 22, 2016
    Run the load and stop at a TA or Petro garage or run the load and leave the problem for the next driver.
  5. Rambler470
    44
    12
    Aug 3, 2015
    I would never just leave the problem for the next guy without reporting it. I would have to be having an extremely terrible day...
    The thought to stop at the petro after unloading did cross my mind. I will have to deal with it in the morning. It was a live unload..Still have the trailer.
    thejackal and Puppage Thank this.
  6. coffee mug
    112
    50
    Jan 22, 2016
    I dropped an empty at Keebler that had a blown out tire
  7. Moose1958
    Moose1958 Road Train Member
    15,164
    33,399
    Dec 17, 2010
    Williesburg, Virignia
    Before CSA-2010 I would have picked up the load and took the trailer and got it fixed. Since CSA-2010 I don't put any piece of equipment on the road till it is 100% road legal. The fines can be expensive and I just don't want the points. For me this is not hypothetical it has happened several times. One of the most frustrating parts of being a truck driver is being put into a bad situation like this because a lazy no count piece of trash steering wheel holder decides not to take a few minutes and report a problem, or worse won't do a pre/post trip on the trailer!
  8. G13Tomcat
    G13Tomcat Road Train Member
    11,872
    42,142
    Jun 7, 2011
    ^^^^ i agree, @Exrayman4000 ! Couldn't've said it better myself. PS: Change your avi, back to the original. Thanks, man...and KUDOS! Great post.
  9. coffee mug
    112
    50
    Jan 22, 2016
    I typed in my problems into the internet and a YouTube video popped up showing me how to fix it.
  10. miss elvee
    miss elvee Heavy Load Member
    816
    2,640
    Dec 15, 2012
    Russellville, AR
    First I would attempt a fix. Is the socket loose or just one pin? Sounds like a single pin. In that case I would slather it with dielectric grease and wedge the pig tail in with a shim. A dime or something similar.
    Provided that worked, I would roll the load, then get the trailer properly fixed.
    If that didn'the work, I'd check the bulbs and wiring. Again, fix if I could. If not, roll the repair truck. I don't drag broke down junk.
    There is a special hot place for drivers who drop busted trailers for someone else to deal with. Don't be that guy.
    12 ga and Rambler470 Thank this.
  11. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,424
    Dec 10, 2011
    Weed, CA
    Exray is right. A driver who leaves a pile of crap behind for the next guy is just plain trash. I hate that so many drivers think it's OK to hose the next guy. I mean it, hate is strong medicine, I know, but it's just so messed up, that kind of thinking and that kind of driving.
    In Calexico, a dropyard there, drivers strip sitting trailers for parts to get their trailer going. Hilarious, and annoying.
    My solution to the light problem is as follows:
    1. carry one spare belly light and at least 2 taillights.
    2. Lately I carry a spare flasher.
    3. Carry electrical connections and a electrical pliers, repair corroded wires at a safe stop.
    4. Drive to the next truckstop or dealer, buy the bulbs, or whatever, do the repair myself. If I get a pop from a LEO while I'm on the way, I'm just hoping for some understanding and a warning worst case.
    In any of these scenarios, the driver who left me this problem is a POS and no friend of mine. Although I want to mention, bulbs or corroded wires have a beginning to their fail, and sometimes (rarely) it goes into the $%&# happens file.
