To go low or not to go, that is the question?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tiffany42, Dec 11, 2015.
  1. tiffany42
    tiffany42 Bobtail Member
    11
    Okay, somebody please help me out. Does anybody have any experience first hand with lowering the front steer axle on a 90's model Pete 379 by removing the blocks from the leaf springs? To make a long story short, my boyfriend did remove the blocks and still wonders why a year later the power divider internal bolts and nuts had all shook loose and 3 of them backed themselves all the way out an appereard to have been spit through the gears and chewed in half. The reason for him removing the rear end housing to discover the bolts was 3 loud bang/clunk noises we heard all with in an hour / 20 miles. He says the cause of the bolts loosening is several years of wear and tear "it's just old and shut wears out" is his argument and I say it's the extreme angle on the drive line causing a vibration that shakes the truck violently to the point that I can no longer paint my toe nails while I ride in the sleeper which he blames the rough ride on the road. Anyways, can anybody help me out here with some , anything either way so I can either shut the he'll up and paint my toenails at a stop sign while he looks soooo cool, soooo low or better yet I can paint them while we're broke down on the side of the road with @ll my told you so's.
  3. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    I think you're right n he's wrong
    tiffany42 and KB3MMX Thank this.
  4. tiffany42
    11
    No but seriously, I need more than that.
  5. tiffany42
    11
  6. mountaingote
    2,026
    7,916
    Sep 22, 2012
    Because he wrecked the angle of the driveline
    tiffany42, KB3MMX and Ruthless Thank this.
  7. brsims
    brsims Road Train Member
    5,296
    6,522
    Aug 8, 2009
    Meadville, PA
    An idiot friend of mine did something similar to an old Buick. Long story short, he destroyed the entire front end.of that car.
    Suspension blocks are there for a reason. Suspensions are designed and set up a specific way for a reason. Yes, you can lower a vehicle and change the stance. But it takes a lot more than just yanking the blocks if you don't want major damage down the road. As far as lowering the front end of a big truck, why intha heck would you want to? Big truck is not toy, big truck is too for work to earn income, preferably the maximum amount of income for the minimum amount of expense!
    NWAF, tiffany42 and mountaingote Thank this.
  8. RidinDirty11
    RidinDirty11 Light Load Member
    114
    103
    Aug 20, 2015
    Mountaingote is spot on. Trucks are very sensitive to drive line changes ( they call it pitch). This is why it is so important to check the airbag height adjustment every six months or so. When you change the pitch of the drive line, you are adding additional stress to the input shaft, which connects to your ring gear. A very simplistic way to explain this is it puts the input shaft gear in a bind against the power divider. Most likely if I had to bet, he was pulling parts from the power divider.
    tiffany42, KB3MMX and mountaingote Thank this.
  9. rank
    rank Road Train Member
    9,919
    113,507
    Feb 11, 2010
    You should work on the truck. He should paint his toe nails.
    NWAF, passingthru69, MJ1657 and 8 others Thank this.
  10. rank
    9,919
    113,507
    Feb 11, 2010
  11. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    Your boyfriend is an idiot.
    I need a girlfriend and a truck to drive.
    Send me a pic of the truck.
    KB3MMX, rank and mountaingote Thank this.
