To idle or not idle while sitting in line to get loaded?
Discussion in 'Freightliner Forum' started by joseph1853, Nov 30, 2021.
  1. joseph1853
    joseph1853 Road Train Member
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Ive been pulling a lot of loads from the port and getting loaded involves a lot of stopping and going in a line of trucks until i get to the loading area. I've been turning my truck off everytime o stop which can be upwards of 15 plus times. My question is should i just go ahead and let my truck idle or not? In one since im worried that idling will be hard on my def stuff and fuel economy and the other since is my starter will be taking a beating. What do yall suggest would be the better option? Each time i stop and turn off my truck it will be 10 to 15 minutes before i have to start it and move up so its not just turning it off and immediately turning it back on just to be clear.
    austinmike Thanks this.
  3. bad-luck
    bad-luck Road Train Member
    3,300
    6,063
    Nov 16, 2013
    Baltimore, Maryland
    Your are saving some fuel, with not leaving the truck running. Your starter is taking a beating, and will wear out sooner. You also are not giving the batteries enough time to recharge, so you will be shortening their life as well.
    bzinger, buddyd157 and joseph1853 Thank this.
  4. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    I would split it in half idle at 900 rpm for a while and shut it down. I wouldn't do the start stop routine to often. That is just me.
    joseph1853 Thanks this.
  5. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
  6. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    I didnt think about the batteries. Thanks for your input.
    bad-luck Thanks this.
  7. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Yeah half dozen one half dozen another kinda deal it seems. I feel the same as you do but with these def systems these days im not sure.
  8. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    Swap your battery starter for an air starter, problem solved.
    Bean Jr. and joseph1853 Thank this.
  9. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Are you serious? Never heard of a air starter but seems at least possible.
  10. lester
    2,920
    7,889
    Jan 2, 2012
    NW, Iowa
    They are great till you run out of air!
    Starter and batteries are much cheaper than after treatment systems and worst thing you can do to emissions systems is idle
    roshea, joseph1853 and GYPSY65 Thank this.
  11. Oxbow
    Oxbow Road Train Member
    12,829
    132,884
    Nov 24, 2015
    Til that time when you run out of air.
    Bean Jr., joseph1853 and GYPSY65 Thank this.
