To upgrade or buy newer
Discussion in 'Heavy Haul Trucking Forum' started by Highwolf89, Jan 17, 2015.
  1. Highwolf89
    Highwolf89 Light Load Member
    294
    61
    Jul 30, 2013
    I have a 1996 kenworth with a strong engine I have a cat 3406e pushing 525 hp... But It has a 10 speed and I want a 18 for heavy haul I can get the upgrade done for about 3k and I just need to get my rears reworked they are 3.36 supposly but it pulls beautiful up mountains so don't know if I believe the door ... Truck is almost paid off only 9 more months... I am wondering should I bother with the upgrades or look for something that all ready has what I am looking for I know she is old but she is in good shape...
    Thanks
  3. fencitup
    fencitup Light Load Member
    225
    113
    Jan 12, 2014
    Bronx, NY
    I am not offering any advice or guidance, but I can tell you that the overwhelming consensus on here will be to do the upgrade and keep on trucking.
    passingthru69, Vilhiem, MJ1657 and 2 others Thank this.
  4. dieselfuelonly
    dieselfuelonly Road Train Member
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    If you like the truck why get rid of it? Spend some time and money on making it exactly what you want, plus it's almost paid off. Especially if you're doing heavy haul make sure that whoever does the work doesn't try to throw a cheap 18 speed with a low torque rating in there... I'd imagine your CAT is probably making at least 1850 ft/lbs so make sure the clutch, trans, and the rest of the driveline are up for it as well.
  5. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Coming from someone that has actually hauled heavy loads, get the truck for the job. Yeah you can try to "make it work", but if you are going to go over 6 axles, you will break stuff that wont be cheap to fix.
    A HH truck will have the following as a rule...
    Bigger radiator, 46k rears, at least 16k front or 20 with twin steering boxes, double framed or the heavier single frame and possibly an insert, larger trans cooler, HH 5th wheel, heavier driveline, and so on.
    If you are going multi axle (3+2, 2+2+2 etc) then get the truck to do it.
    To go up to 6 axles, you will be fine as you are. A heavy front end, at least 14k, will be a godsend. At least 44k rears will also be as nice for states that allow it. A 40k set of drives is only rated to pull so much weight period. So even if you have 40,000 on the drives, and you are grossing 150k plus, you are going to put a LOT of stress on the driveline and rears, and they will break at the worst time.
    My current truck was a bargain, but if I was to go back to a 4 axle truck, I doubt I would just hack this and slip another axle in there. It can be done, but there are lots of other things that go along with it. In my case, heavier front axle and suspension, heavier rears, heavier trans and cooler, different ratio, and so on. Compare all that to trading it for a 4 axle, and it makes little sense if you want to do it right.
    Just my .02 from actually doing it for may years, as I crack up when I see a normal 3 axle going down the road with a multi axle trailer with a driver thinking "I dont know WHY them guys spend all that money on a 4 axle truck".
    Martin
    HighCountry, Cetane+ and wore out Thank this.
  6. Ok big boy
    Ok big boy Light Load Member
    91
    102
    Jan 22, 2014
    I too cannot not offer advice or guidance ,but the above post is spot on from my perspective.I have a friend who has a 4 axle tractor with a 2 axle RGN with a flip axle. Normal 130000 lbs gross. Always trying to save a buck. Buy's a pete 379 1.1 million. Factory 260 wb 3 axle setup for legal hauling. Stretches the frame for 120 " ICT. 1 year later stretches it again for adding a lift axle. Then double frames part of it. Truck has had radiator, power divider, transmission, head, turbo,and other issues. He has spent a ton of money on this thing. I hate to see anyone else fall into the trap he is in.
    Proceed with caution. Have you talked to any big truck driveline shops locally for there feedback ? Good luck to you !
  7. Patronas01
    Patronas01 Light Load Member
    132
    79
    Dec 23, 2014
    California
    I agree with leftlanetruckin and Ok big boy some times you spend a lot more money to get a vehicle upgraded to do a job it was not designed to do, then buy one that was factory build and at the end you may not get what you wanted,
  8. 201
    201 Road Train Member
    12,439
    25,440
    Apr 16, 2014
    high plains colorado
    Hi Patronas, that's true. I found that out with a Harley I bought once.
  9. fencitup
    225
    113
    Jan 12, 2014
    Bronx, NY
    [QUOTE="semi" retired;4418181]Hi Patronas, that's true. I found that out with a Harley I bought once.[/QUOTE]
    What were you hauling with the Harley ?
  10. 201
    12,439
    25,440
    Apr 16, 2014
    Ha, good one. Just me.(no riders, get your own bike)
  11. Highwolf89
    294
    61
    Jul 30, 2013
    I'm not really looking to do super super heavy that u will need a lift axle just more over size and why not and such forth..
