Tolerance for being over weight?
Discussion in 'Questions From New Drivers' started by freightlinerman, Apr 10, 2014.
  1. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Is there a tolerance for being over weight? Let's say 20 pounds on your tandems? Or 100 pounds on your steer? Some times these CAT scales are quirky. Not only that, but when driving some things tend to bounce around a little and change the weight by small margins.
  3. kw550cat
    kw550cat Medium Load Member
    663
    596
    May 22, 2012
    brooklyn, new york
    When I pulled a tank I would get overweight on my axles but be below gross. If the scale master knows what he is doing he would let me go because there is nothing I can do. The axles don't slide. If it's an idiot then they will write you up.
    D.Tibbitt, farmerjohn64 and tommymonza Thank this.
  4. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    I don't know that there are any hard and fast allowances among various states but in my experience, 500 lbs over (according to Cat) at various weigh stations has never gotten me ticketed or hassled. That's not to say they can't issue a ticket for 200 lbs over if they were in a mood, but it's highly unlikely. Seems that some might be more prone to issue a citation for over gross, rather then over axle.
  5. lonewolf4ad
    lonewolf4ad Road Train Member
    7,743
    7,773
    Nov 4, 2008
    Displaced to Colorado
    While I was driving I did have occasional times when load shifts caused me to become over axle (I never rolled from the customer that way other than to the nearest scale and back). The extra time to get a load corrected was worth it to me in order to insure 1 less possibility for an inspection if I crossed a scale.
  6. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    I know MI does. its a percentage on each axle. Used to have a ticket in the truck with it right on the top. 10 percent maybe? but you still couldn't be over your gross.
    jamespmack Thanks this.
  7. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    That's nothing.Very much doubt they'll say anything.Think most have a 500 lb leeway.I've been over many times by a few hundred lbs and they didn't say anything.
  8. Pound Puppy
    Pound Puppy Heavy Load Member
    974
    868
    May 31, 2010
    Amherst, OH
    All tolerances are discretionary by the officer. But A couple hundred pounds on a tandem or drive i wouldbt worry, Ive never had an issue (knock on wood). Keep in mind many, not all, but many have 400lbs exemptions for trucks with APU's. Theres lists up online.
    Toomanybikes Thanks this.
  9. Clyde07
    Clyde07 Heavy Load Member
    809
    1,927
    May 28, 2013
    The only rule I know is this: If you're in Illinois, the afternoon before a holiday, and the weigh master is going home in 10 minutes, AND you're too stupid to scale before you hit the coop because your bills said 38,000. Well, he'll let you pull around back, adjust that 37000 lb drive axle, and be on your way with no citation. I don't really believe in luck, but...
    D.Tibbitt and Rugerfan Thank this.
  10. Toomanybikes
    Toomanybikes Road Train Member
    2,360
    3,120
    Apr 8, 2009
    I seen drivers with tickets of 180lbs-200lbs over axle.
    These tickets were an ag product in a bin so they were subject load shift. Hard to secure Apples or Corn cobs.
    Yet the tickets stuck.
  11. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    in utah, your allowed 1%. axles have to be legal.
    in montana, your allowed 1000 lbs. axles have to be legal.
    depends on the state and the man in charge at the time your rolling through.
    bzinger Thanks this.
