Tolls
Discussion in 'Ask An Owner Operator' started by NHL_fan, Dec 28, 2013.
  1. NHL_fan
    NHL_fan Light Load Member
    103
    34
    Jun 20, 2011
    NoVa
    Hi drivers!
    I have a questions to O/O. How do you guys deal with tolls? Do you prefer to pay cash? Or you order different transponders? I really don't like to stop to pay cash and waste my time. Also having transponders give some discount. The problem is one EZPass isn't enough, there are so many of them like OK pikepass, Kansas K-tag, Florida SunPass, etc... I run 47 states (no Cali) and looks like I have to set up all of them if I dont want to stop paying cash and lose time. Is it worth it? Or should I just forget about it and pay cash? What do you drivers prefer? I need your opinion.
    Thanks.
  3. dog-c
    dog-c Road Train Member
    1,852
    1,546
    May 30, 2011
    New York, NY
    Get them all. Ez pass offers discounts, the others I don't know but it is worth the time you save
    NHL_fan Thanks this.
  4. KF7WTV
    KF7WTV Medium Load Member
    410
    234
    Aug 8, 2012
    RENO, NV
    I was recently informed by one of the folks at Central Oregon Truck that several of those "little guys" will begin accepting EZ Pass next year. I'm sure you can find some info on their respective web sites. That would make your choice easier. :biggrin_25519:
  5. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    I paid cash for the last 10 years and finally decided to get a EZPASS. Some toll agencies are doing away with EZPASS discounts where others are reducing them. EZPASS is decent, but the transponders have issues in some vehicles. Also some states only have one style of transponder (Ohio only has a inside one that doesn't work well with my stainless drop visor). Another bad issue with EZPASS is that I run a tandem axle reefer with the front axle being liftable. EZPASS generally won't recognize the axle being lifted considering the transponder is registered to a 5 axle tractor trailer.
    NHL_fan and RedForeman Thank this.
  6. CellNet
    CellNet Light Load Member
    206
    82
    Jun 19, 2011
    Chicago IL
    Is there a difference between Ipass and EzPass?
  7. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,138
    Jan 30, 2011
    Best thing would be to start with an EZpass since it covers just about all the toll roads in the NE. Then figure out where you'll actually use others before going thru the trouble. I have FL Sunpass, TxTag, OK PikePass, in addition to EZpass. I don't use any of them often, but it sure is nice to not stop and pay cash tolls when I decide to run pay roads.
    So in addition to pullingtrucker's excellent points about function, especially about non-standard or changeable axle configurations, here's a few more:
    Get the removable type transponder when you can (avoid the sticker style). You won't have to re-order when replacing windshields and you can remove them when not in use to reduce clutter on the windshield.
    You can get EZpass from any participating state. I think I've read that NY has the best program for terms and billing. I signed up with PA and it was a mistake. I went to PA since that was the main state I planned to use for EZpass tolls. Huge cash balance required (due to their ridiculous toll rates no doubt) and poor customer service. Example: a few months ago I took a short trip between Breezewood and Bedford, about 16 mi. The transponder didn't register so they automatically charged me the max toll from the entry point, about $80. In order to get that reversed, I had to print out a protest form, fill it out, attach proof (their own records where the one toll plaza didn't register), and send it regular mail. 3-4 week turn around. In the mean time they just kept my money. You're guilty until you prove your innocence. They will not do any adjustment over the phone, even if it's obvious.
    EZpass tolls from other than the state you're signed up with may post with delay. On mine, it takes a day or two for WV tolls to show up on my PA account. If you have to protest those, I'm sure PA will make it even more difficult and do less for you. See last paragraph.
    TX has many toll road authorities. They generally interoperate, but there are cases where they don't. It can make disputes time consuming as you figure out who has to fix it. Of course you will do all the legwork, waiting on hold, and on the hook for tolls/penalties while figuring that out. Best to figure out which toll roads you'll use and make sure the one you sign up for works on all of them. Especially when traveling on unattended toll roads. I chose TxTag since it covered most of the tollways around DFW and Houston. Oddly, I dodge TX tolls more often than I ride on them. You can travel the feeder roads and avoid tolls at the expense of a lower speed and traffic light every mile or so. Costs minutes in most cases, not worth the hefty toll.
    Definitely look at the rates before just gliding thru the express toll lane. FL is a good example. Sunpass on the FL turnpike is generally a good value. On the other hand, the Orlando toll road network is spendy. Most cases you only save minutes and there are plenty of good free routes. Another example is the PA turnpike. The rates will make your eyes pop out. A trip from OH to Philly will rack up nearly $200 for a 5-axle semi.
    Last, but not least, if you have driver employees, use caution with toll tags. A lazy driver can cost you.
  8. nabil1127
    nabil1127 Bobtail Member
    41
    6
    Sep 15, 2013
    hey, I had the same with my liftable axle on my flatbed and tag axle on my truck, but if you contact your ezpass agency and change your transponder into 3 axle vehicle instead of 5 axle it will then read however many axles you have on the ground and will not read 5 axles all the time.
  9. amiller
    amiller Medium Load Member
    475
    249
    Nov 26, 2012
    Charlotte, NC
    The company I work for uses ipass. It works everywhere that ezpass is accepted
    NHL_fan and CellNet Thank this.
  10. commontrack
    commontrack Bobtail Member
    47
    22
    Aug 25, 2013
    Reno, NV
    Here are the toll transponders you'll need:
    EZPass for the NE toll ways also covers IL/IN tolls and FL Sunpass
    Pikepass for OK
    K-Tag for KS
    TXpass for TX
    As far as I know Pikepass, K-Tag and TXpass are not authorizing EZPass use yet.
    The pluses you have for these is they all have a setup for monthly accounts that give you a discount and you can write the expenses off on your taxes.
    Don't forget you can get the EZPass/Prepass combo. If you decide to do CA, the Prepass will help with the scales.
    CellNet and NHL_fan Thank this.
  11. Ruthless
    Ruthless Road Train Member
    8,810
    86,343
    Aug 28, 2010
    The City.
    I have an ezpass. I run mostly northeast so it saves enough time to be worthwhile I feel.
    I also have a 13" stainless drop visor, the interior transponder does get missed about 30% of the time: it gets picked up via camera on the toll booths and assigned to my ezpass account (with no additional surcharge for the transponder not being read) by my license plate info.
