Tool Kit
Discussion in 'Prime' started by BigSky, Nov 1, 2015.
  1. BigSky
    BigSky Light Load Member
    186
    174
    Jun 28, 2015
    Looking to build a tool kit to have on the truck, what would you recommend?
    farmboy73 Thanks this.
  3. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
    Lowe's sells a Kobalt tool bag combo kit which is a good start. Box wrenches...Caging Bolts are good to have...
    BigSky and Cottonmouth85 Thank this.
  4. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Depends on how much of a mechanic you are. For the average person a quality pre made kit will suffice and save room.
    BigSky and Straight Stacks Thank this.
  5. Cottonmouth85
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Great minds think alike, eh?
    Straight Stacks Thanks this.
  6. AModelCat
    161,904
    Basic tool kit with metric/standard wrenches and sockets. You can save money and space by buying some large adjustable wrenches to cover the larger size bolts/fittings (12" and 15" should do the trick). Screwdriver set and pliers/vice grips ar a must as well. Wouldn't hurt to buy an oil filter strap wrench as well in case the mechanic doesn't tighten the filter properly and it vibrates loose and leaks. A 4 or 5 lb hammer is handy if you need to beat on seized pins or brake drums.
  7. Cottonmouth85
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Get like 3 9/16 wrenches. Everything on a truck is 9/16 haha
  8. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    A small set of combination wrenches for brakes, a medium to large crescent wrench or two for changing gladhand/airlines, slip lock pliers, scissors, pry bar, flashlights, fuses and extra 25-30a, electrical butt conectors, test light, electrical tape, rescue tape, and a pink bunny.
    That's what I have used the most and probably forgetting something but that's a good minimal start.
  9. AModelCat
    161,904
    Speaking of flashlights, do yourself a favour and buy a powerful LED light with a magnetic base. They're more expensive than a regular flashlight but you can stick it to the frame or axle near where you are working and free up your hands. Really nice for those midnight repairs that require 3 hands to begin with.
    100 Percent, PChase, truckon and 5 others Thank this.
  10. Cottonmouth85
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Variety is the spice of life... and the tool kit. Different size drives and adapters. Standard and metric. Regular and deep well, 6 and 12pt etc...
    No need to break the bank but don't cheap out on truckstop tools.
    Straight Stacks and BigSky Thank this.
  11. darthanubis
    darthanubis Heavy Load Member
    825
    616
    Jun 26, 2015
    So far the overpriced one on the list you get from the company store when issued your own truck has sufficed. I added a pair of vice grips, hammer, and cable cutters to break some of these cable seals.
    BigSky Thanks this.
