Tools for trucking
Discussion in 'Questions From New Drivers' started by Bama Roadrunner, Mar 27, 2017.
  1. Bama Roadrunner
    Bama Roadrunner Light Load Member
    126
    38
    Jul 19, 2015
    North Alabama
    What tools should I use for when I'm in the road? What tools should I bring or should I buy a set of tools?
  3. Txdriver77
    Txdriver77 Medium Load Member
    365
    26,641
    Sep 7, 2016
    Texas
    screwdriver with different bits, pliers, adjustable wrenches, socket set, vise grips, claw and rubber hammer, prybar/crowbar, pushbroom(dryvan), duct/electrical tape. whatever you can fit in a small to medium tool bag.
    DRAGON64, Bama Roadrunner and pattyj Thank this.
  4. Boattlebot
    Boattlebot Road Train Member
    1,666
    21,079
    Aug 7, 2016
    I get by with a small socket set bigger vice grips and one of those 8 piece multi bit flashlight screwdriver dodads.
    Bama Roadrunner Thanks this.
  5. Suspect Zero
    Suspect Zero Road Train Member
    2,508
    9,518
    Oct 10, 2016
    Burbank, IL
    51.50 Heavy Load Member
    894
    1,942
    Jan 20, 2016
    Salem Oregon
    Rubber snubbers, spare bulbs, flashlight,
  7. Txdriver77
    365
    26,641
    Sep 7, 2016
    Texas
    almost forget to mention work gloves. extra glad hand seals, pens. get a block of wood incase you ever high hook the king pin, a small 4x4 will do the trick. step stool or ladder. save your grocery bags and use those as trash bags while you're out driving.
  8. Boattlebot
    1,666
    21,079
    Aug 7, 2016
    Oh if your pulling reefer get a load strap or two of your own. The one with etrack hooks. They work a metric #### ton better then load bars.
  9. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,982
    18,764
    Mar 9, 2014
    In a van down by the River.
    This. Plus I had a multiman tool. Actually used that more than anything. I would add duct tape and electrical tape. Wire strippers and wire nuts that merge 2 wires.
  10. Ridgeline
    22,379
    116,155
    Company driver = nothing
    You call the company and have them get it fixed.
  11. kemosabi49
    10,628
    45,510
    Jan 13, 2013
    SW Arkansas
    Duct tape, some basic tools and WD-40.
