top load vs center load antenna
Discussion in 'CB Radio Forum' started by fgb3, Dec 18, 2011.
  1. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    Morning Rat .....
    Fiberglass antennas don't like to hit things ..... I've lost a few HAMSTICKS to a low object .....
  3. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    I have, and that's what I run also. Wilson 1000s on my four wheelers. When tuned properly I can't tell one talks any better than the other. I can see where they wouldn't hold up where Rat lives.
  4. am89
    am89 Light Load Member
    101
    12
    Aug 1, 2010
    METRO NYC
    You don't have to be a radio enthusiast to understand,that a metal whip will outlast a fiberglass rod,in a truck environment.It's just plain common sense.
  5. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    Here's one antenna test results, toploaded fiberglass won, of course. Vast. = RX , Lähetys = TX
  6. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    How was it done :biggrin_25513:
    What kind of control and referance :biggrin_25513: was used.
    There are many things you have to do to get a good result you just can't put a ant on a pole and print numbers ....
    There was a add years ago for a RUBBER DUCKY antenna that said 186 DB gain !*
    * Over a wet noodle down a 1,000 foot well ....
  7. V8Lenny
    1,016
    130
    Aug 3, 2008
    Europe
    There were 6 receiving stations (4 close and 2 far-away) giving signal reports on TX , RX numbers were of course from test station.
  8. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    BUT what is the referance ? S units ? DB ? its fine to do a field test but what do the numbers relate too ?
    Nice start with relitive readings .....
  9. AB7IF
    AB7IF Light Load Member
    205
    103
    Jun 11, 2011
    Somewhere, Ar
    Units are meaningless since these are ratios and units therefore cancel. Whatever the units are they were all the same per each antenna. In other words if S units were compared between antennas then all the numbers are S units. Simple math shows that units/units = one. S/S = one. dB/dB = one. Negated. Unity. Gone. Zilcho. Nada.
    What you should concern yourself with is the huge number of other errors. Such as did each antenna have identical SWR, identical mounting location and ground plane, and so on. I would find it hard to believe these factors were all the same. Some form of correction factor would be needed and I would think this factor would be very hard to derive.
  10. V8Lenny
    1,016
    130
    Aug 3, 2008
    Europe
    S units, average from those 6 stations.
  11. V8Lenny
    1,016
    130
    Aug 3, 2008
    Europe
    I don't know about SWR, probably not the same because some antennas don't get as good SWR as others. Location was the same, some antennas used same base, some had their own base. It's hard to get all the factors same but I think this was still a nice test.
