Top of my air compressore on my c15 acert leaking by
Discussion in 'Trucks [ Eighteen Wheelers ]' started by N14 cummins power, Dec 6, 2011.
  1. N14 cummins power
    N14 cummins power Bobtail Member
    38
    Dec 1, 2011
    Lampasas tx
    Anyone know why this is I don't know much about cat or anything but it leaks pretty good out of it anyone know why?? And could it cause any other problems besides air Loss of course???
  3. 05379
    05379 Light Load Member
    115
    Nov 15, 2008
    montague ma
    is it leaking from a little plate with two screws holding it down?
  4. N14 cummins power
    38
    Dec 1, 2011
    Lampasas tx
    Yea that's where it's coming from
  5. 05379
    115
    Nov 15, 2008
    montague ma
    that is your compressor unloader valve you need a new one or you can take out and try cleaning and re install to get you by maybe lube o rings with little lite grease what model is your comp? if it's same as mine i got part number at shop but won't get it to you till tomorrow night
  6. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    If it is leaking from the little plate with the screws in it then that is the unloader valve. More than likely you have a broken o-ring in it and/or the unloader is coked up (burnt oil residue). Both are common problems on the ACERT motors.
  7. N14 cummins power
    38
    Dec 1, 2011
    Lampasas tx
    Ok thanks guys well will try to get that fixed to them I just got this thing and it seems like it keeps adding up and adding up but will see what I can do u ain't going to be out here on this road with out putting money into them though!!
  8. PonderTrucker
    PonderTrucker Bobtail Member
    5
    Ponder, Texas
    Yep, you need an unloader kit. I just bought one for a 2006 Acert C15 just a week ago from KW in Dallas for about $100. I was surprised it cost that much, but that KW for you...
    Very easy to install. You can try cleaning your old one, but often times the o-ring breaks apart and the spring is often times worn out.
  9. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I'm sure about bad unloader valve, but identify your compressor first!
    Is it Wabco, Knott, Bendix, Holset???? Parts differ and prices too!!!
  10. Roberts s 51
    Roberts s 51 Bobtail Member
    Why on a bendix air comp on c15 this big line on top of comp keeps blow that line and fitting out which pulls threads out of head
  11. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    There was a bulletin that addressed this issue....got rid of the steel line and replaced with a stainless/Teflon hose. See your local CAT dealer for parts.
    Oxbow Thanks this.
