Total newb with a question.
Discussion in 'Questions From New Drivers' started by cellardoor, Dec 25, 2007.
  1. cellardoor
    cellardoor Bobtail Member
    Saint Charles, MO
    I wasn't sure whether to put this in the 'questions from non-truckers' forum or here, since I am only really investigating trucking right now as a possibility and haven't researched it yet enough to see if it's something I want to go into.
    In the process of looking into it, I have run across a lot of ex-truckers complaining about back problems and injuries and the like. I don't have a bad back or any back problems that I am aware of, but I don't intend to develop them, either.
    I assume this mostly comes from loading and unloading the trucks, and I guess my question(s) are as follows:
    (1) is this aspect of the occupation an issue of people being careless and not carrying loads correctly or something, or is it an inevitable aspect of the work?
    and if so, then,
    (2) is this aspect of the job itself unavoidable? How common are jobs that don't require you to load and unload the trucks? are they common or impossible to find? Is it realistic to expect to find work that does not require live loading/unloading on a regular basis? If so how does the pay etc. compare with other options?
    This seems to be an "occupational hazard" of sorts that I am finding a lot of mixed signals about, and if you could clear it up I would be grateful.
  3. SockPuppetNinja
    SockPuppetNinja Bobtail Member
    11
    Olympia,Wa
    Well not to be mean to any truckers but when you weigh 300lbs back problems are inevitable. Two years ago I got out of the Air Force for the Air Guard and starting driving truck. Its not a bad job if you can find a carrier that pays you for what you do. I have found many of he common carries do not. People told me I would gain weight driving trucks which never happened. I drive 5 days a week and have the weekends off and I do situps, push ups and I run on my treadmill which takes me about an hour from start to finish. Also changing your diet around helps a lot. Staying away from all the starchy, sugary foods, and switching to wheat bread instead of white and eating something like turkey and chicken instead of beef will make a big difference. Many drivers live off truck stops and can be seen passing you eating hand fulls of cheese puffs, while drinking a 32oz soda. Many drivers have Diabetes Type I and later Type II and have truckers leg with knee and back problems. So if you want to start driving safeguard your health you do not want to be the guy who has to ride the Wal-Mart disabled persons cart because you decided eat 11 hours a day while sitting down.
  4. palerdr
    palerdr Medium Load Member
    554
    16
    Nov 18, 2007
    albuquerque,n.m
    way you lift. Lift with your legs and not your back. Squat with your back straight and head up and lift with the object close to your body. Most people don't lift that way. There are lots of jobs that don't require loading or unloading. Many companies have a drop and hook operation.....all you do is switch trailers and be on your way. There are also tanker jobs, dump trailers, flatbeds ( you'll obviously have to secure the load and tarp it ), auto carriers and what else.... cattle and bull haulers, don't know much about that though. Oh yeah, and trash haulers.. similar to dump operations but many of the trailers have moving floors that just convey the stinkin' garbage right off the trailer. I almost forgot intermodal.....a real pain in the ##### if you ask me. Then you have the mail carriers who most likely just dock it and roll the carts of mail off the trailer. At least that's what I did when I did that for a short period.
  5. myminpins
    myminpins Road Train Member
    1,578
    65
    Sep 20, 2007
    Dartmouth, NS, Canada
    I believe a lot of people used to get back trouble because of the old seats in trucks, too. Today's newer air seats are much nicer to the body as are the air ride tractors.
    As far as lifting, there are lots of places where you're never required to lift or unload your truck. Most places don't require you to lift more than 100 pounds max and oftentimes you have a cart or forklift to help you unload, it really depends on what you're moving and unloading.
  6. palerdr
    554
    16
    Nov 18, 2007
    albuquerque,n.m
    help somewhat. When people are in a hurry to get the job done, it's natural to forget how to lift safely, but if you're concsious about it you can most likely avoid a major injury while lifting. I personally will not handle freight. I've been there, done that. Never again.
  7. alot-to-learn
    alot-to-learn Light Load Member
    118
    31
    Jun 13, 2007
    inverness Fl
    I have a "bad" back two of my discs are nearly closed. after 6 months behind the wheel it isn't any worse then when I started.
    I've lost about 12 lbs so far and walk as much as I can when not rolling.
    I see some drivers try to park as close as possible to the T/S so they don't have to walk, some of these guys are really, really, large and could benefit from some exercise.
    my back is bad from 20+ years of hard labor jobs, I drive now and I've yet to unload a single trailer.
  8. gitrdone5782
    gitrdone5782 Light Load Member
    71
    Dec 22, 2007
    Lima Ohio
    99% of driver dont unload there own trucks
  9. jimnfor
    jimnfor Light Load Member
    63
    7
    Dec 23, 2007
    sherman, tx
    as one of the people above said, not to be mean, but weight really seems to be an issue for all the 'complaints' drivers have. stay active, park as far as u can from the truck stop(unless you get that PERFECT spot up front thats a pull-thru, lol). watch what you eat because your metabolism will slow down for sure sitting in that truck for extended periods. that being said, stop every 2-3 hours, get out and walk. alot of drivers i know out here, drive for 6hrs at a time without stopping, NOT GOOD!
  10. palerdr
    554
    16
    Nov 18, 2007
    albuquerque,n.m
    I think the regional drivers that deliver to grocery warehouse have to unload their truck. That's how it was years ago when I lived back east. OTR drivers are probably not required to do that as much due to the longer hours behind the wheel, I would imagine ? Not sure. All the regional drivers from the various companies had to unload I remember. That was a nightmare . Dealing with those bums at those places was half the problem. The recievers didn't care if you waited 3 hours AFTER you unloaded just to count the crap and sign you out. That's how I remember it.
  11. palerdr
    554
    16
    Nov 18, 2007
    albuquerque,n.m
    is that all? lol, I've driven 9, 10 ,11.. sometimes ! The right thing to do is stop for breaks. There, I corrected it so it sounds more logical.
