Tough situation to call the cops or not on a fellow trucker?
Discussion in 'Questions From New Drivers' started by Mototom, Sep 8, 2021.
  1. Mototom
    Mototom Road Train Member
    1,388
    2,703
    May 7, 2019
    So this is kind of a weird one.
    I was running 65 in TN and see this flatbed pulling some big grey iron box beams or tower legs.
    he had it strapped but three out of the 5 or 6 on the top row were loose.
    When I say loose I don’t mean vibrating, I mean catching wind like a parachute 3-6inches of space between the parasail and the load.
    I don’t trust my self to run beside someone and try to yell out the window and don’t have a CB radio. So here’s the question.
    should I have called the local police dept?
    (Company name was in too small of letters to read when he passed)
    I don’t want anyone to get a ticket lose a job or be on the #### list of their company but I’d have felt horrible if the load would have killed someone.
    I ended up just following him for a while to see if he’d pull over and after about 20 minutes he did, so I’m satisfied with the outcome.
    what would you have done in the above situation had the driver not pulled over?
  3. Lucky12
    Lucky12 Medium Load Member
    600
    2,297
    Nov 24, 2019
    Simply getting the drivers attention by waving and then pointing back to his load ought to alert him that something back there is wrong. Likely he would pull over and check it.
  4. jamespmack
    215,834
    Good reason for everyone to run a cb huh?
    I personally would appreciate being told about it on the cb, vs someone calling the law.
    But that is trucking etiquette That is mostly lost.
  5. Mototom
    1,388
    2,703
    May 7, 2019
    I’ll give you a 100$ if you can get a ####ing radio to work on this truck.
    I’ve bought two different radios 3 different antennas and several coax cables.
    I’ve already spent enough money on #### that doesn’t work.
    and I’m not kidding
    gentleroger and jamespmack Thank this.
  6. Espressolane
    17,558
    107,607
    Calling law enforcement should be the last resort. Do that if it really looks like a major problem. Flapping straps is a problem, how much is the question.
    some things you could do.
    Get a radio. It comes in very handy for a lot of things.
    One thing I have done, because of no radios, is print off some signs. Printed large enough to read when along side the other truck.
    All they say is
    “ Check trailer for flat tire”
    “ No trailer lights”
    “ Check your Straps/Chains”
    Put them in a plastic binder sleeve.
    The one I have yet to use is “ Trailer is on FIRE”
  7. jamespmack
    215,834
    Buddy your money would be wasted. I'm not radio guy. Simple cobra, one antenna, power and ground kinda guy.
  8. Grumppy
    3,091
    10,604
    Dec 11, 2010
    West Monroe, La
    If his straps were that loose, they didnt just get that way in the last few minutes. They've been that way for some time. He knows.... he's been told or people have tried to tell him. He's just lazy.
  9. Lonesome
    Lonesome Mr. Sarcasm
    11,194
    22,992
    Dec 15, 2007
    Northern Indiana
    Just because you have a CB radio, doesn't mean the other guy does.....
    Snailexpress and 88 Alpha Thank this.
  10. Kyle G.
    Kyle G. Road Train Member
    3,853
    20,233
    Jan 23, 2016
    Eastern Iowa
    As a flatbedder, my assumption is this was probably one of those “It’ll be ok, It’s just going down the road” types of drivers. He probably tightened two of the straps and just hand tightened the rest to make it look good (even though it didn’t actually look good, but you know what I mean).
    D.Tibbitt, BigBob410 and Mototom Thank this.
  11. Mototom
    1,388
    2,703
    May 7, 2019
    I just assumed it would fall off/shift easily but I’m paranoid enough I secure my dry van stuff as well as some flatbedders do their loads.
    Guess looks are deceiving
    D.Tibbitt and Kyle G. Thank this.
