Howdy all! I finally got the Volvo out of the shop after 3 months. Yes, they took me for a ride. When I picked up the truck, the side repeater and mirror turn signal weren't working. They blew me off and side it was probably just a pinched wire in the door. Decided I had enough of them, so I took the truck home.
I found a broken wire in the mirror and re-soldered it. However, the mirror lamp and side repeater still don't work. The display says, "short circuit LH side repeater."
I traced continuity in the wires leading to the mirror - they check out. I checked continuity leading to the side repeater, again fine. I checked the switch, power coming out of it. So it must be a break somewhere between the switch and relay, or after that.
My question for this part of the forum is this: Does it sound like I'm on the right track? Any suggestions on where I'll find the splices? The wiring diagrams don't show actual locations. Is there a common problem related to this issue with the Volvo's?
I'd appreciate any suggestions. Thanks in advance. 2009 VNL670 with a D13 and I-Shift tranny.
Tracing a short circuit on my side repeater.
Discussion in 'Volvo Forum' started by Michael H, Oct 5, 2016.
If it says SHORT CIRCUIT it mean hot wire connected to the ground. Open a mirror light and check with ohmmeter. Could be a short in bulb socket. Trace the hot wire in the door and under dash for bruised insulation.
Thank you! I'll let you know what I find.
Thank you for the advice. I was able to fix the problem, after many hours of searching and tracing wires. I don't know if I fixed it, or if it just started working on its own. We'll see if it's still working in a week. I appreciate your knowledge and willingness to share with me.
I have a problem with my 2013 side repeater.& mirror ligjt. Did anyone ever really find the short we all experience with this model volvo 670 with the i shift?
