Tractor Maxi knob applies trailer brakes too
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 04 LowMax, Dec 28, 2023.
  1. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    94 Peterbilt. When you pull knob to set tractor brakes, trailer maxis come on too. Even if you hold trailer knob in. You don't actually have to hold trailer knob in because it doesn't pop anyway. When you unhook for bobtail the red trailer button does its job as it should. I'm thinking something is plumbed wrong to make the trailer maxis come on with the tractor? I've never seen this in over 45 years of driving t&t. Anybody have some ideas? It was a log hauler once upon a time and I wonder if someone modified it so everything came on with 1 button when spun out on a hill.
    Oxbow and '88K100 Thank this.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    Bad tractor protection valve? Check air supply from park valves to it.
    Oxbow and 04 LowMax Thank this.
  4. '88K100
    '88K100 Road Train Member
    1,263
    2,663
    Aug 23, 2020
    I drove ‘87 ford like that,,drove it new off the lot…first time it really annoyed me i woke up and had to get out and beat frozen trailer brakes after a night of drinkin’. After that i would park level ground and drop a wheel chock….only drove the truck for a year,,,,,,another oddity of the truck was it came with a manual window washer pump…that i changed immediately
    04 LowMax, MACK E-6 and Oxbow Thank this.
  5. Heavyd
    Heavyd Road Train Member
    7,752
    6,185
    Feb 4, 2009
    Bendix park brake valves are designed that way. Both buttons in, pull out only the yellow, both pop. This a safety regulation.
  6. 04 LowMax
    440
    250
    Feb 3, 2013
    Alberta
    Yes. But usually you can hold the trailer knob while you pull the yellow and only get tractor maxis on. Not this one.
