Tractor securement
Discussion in 'Flatbed Trucking Forum' started by jellybean, May 22, 2013.
  1. jellybean
    jellybean Medium Load Member
    324
    65
    Mar 1, 2010
    Central MD
    I was parked next to a guy hauling 3 Massy Ferguson dl260 tractors with buckets. He's hauling them on a 48' flat. He has two straps on each tractor one over the front tire on over the back tire. That's all the securement he has no chains or binders. I'm not a flatbed driver but is this ample securement? I wouldn't feel comfortable hauling a load worth a couple $100 grand with 6 straps. Just curious. Thanks.
  3. critters
    critters <b>Late For Dinner</b>
    1,444
    2,440
    Jul 16, 2011
    traverse city,MI
    Legally ? Yes straps are rated at 5600lbs 5600 lbs each. if they are 4" . Those tractors are less than that
    Safe ? Not in my opinion,I'm a flatbedder/heavy hauler I believe in chains and over securment.
    Working Class Patriot and SHC Thank this.
  4. BrianE
    BrianE Light Load Member
    164
    79
    Mar 9, 2013
    Livingston Texas
    I deliver tractors for a Kubota dealer. No way do I ever use straps on a tractor. Chains and binders and I lock the binder with the extra chain. I use straps for mowers, rtv's and small implements, that's all they are good for in my world.
    Working Class Patriot Thanks this.
  5. GOV'T_Trucker
    GOV'T_Trucker Heavy Load Member
    782
    667
    May 28, 2011
    They all do the same thing... They all have a rating for a legal amount per strap.. As long as the straps are equal or more to the weights of the tractors he is fine... Sure chains look better and make it seem more secure but thats about it..
    Now when I was flatbedding I wouldn't use straps for things like equipment, coils, dies and varies other things.. But that was my preference.. Besides like I said it looks better with chains, less chance the DOT will want to take a closer look at your ways of securement..
  6. JDP
    JDP Medium Load Member
    377
    404
    Sep 25, 2011
    Dubuque, IA
    From what I can tell according to FMCSA 393.128 securing a tractor of this size with straps over the tires is illegal. I'm assuming this unit w/ loader is less than 10k in weight. That puts it in the same securement category as cars/trucks/ and light equipment. And the below quote from FMCSA said you need to secure the unit from integrated tie-down points or over the tires with the use of straps that cradle the tires like tow-truck operators use. 4" straps are not specifically designed for this, nor are they using specified tie-down points.
    (b) Securement of automobiles, light trucks, and vans.
    (1) Automobiles, light trucks, and vans must be
    restrained at both the front and rear to prevent
    lateral, forward, rearward, and vertical
    movement using a minimum of two tiedowns.
    (2) Tiedowns that are designed to be affixed to the
    structure of the automobile, light truck, or van
    must use the mounting points on those vehicles
    that have been specifically designed for that
    purpose.
    (3) Tiedowns that are designed to fit over or
    around the wheels of an automobile, light truck,
    or van must provide restraint in the lateral,
    longitudinal and vertical directions.
  7. G/MAN
    G/MAN Road Train Member
    7,031
    8,622
    Sep 3, 2010
    I prefer chains on equipment, such as tractors. Are you talking about tire straps? If so, that is what many car haulers are now using to secure their cars. If you are talking about using 4" straps across both tires, then that is likely not a good way to properly secure a tractor. Back when I pulled Case Holland skid loaders, we had to use 1 strap and 1 chain to secure them. I would usually haul 4 or 5 on each load. If something has wheels it is usually good to secure it where the securement is pulling from opposite directions.
  8. Cluck Cluck
    Cluck Cluck LTL Wizard
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    You should've punched him in the nose.
    fisher guy, Clasix1055 and MJ1657 Thank this.
  9. fisher guy
    fisher guy Road Train Member
    1,993
    1,060
    Mar 22, 2009
    Ocala Florida
    i agree with this fully
    379exhd Thanks this.
  10. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    no, they don't do the same thing. Chains hook into themselves and are inherently resistant to sharp edges. Straps are for going over the load and hooking to the other side or to a suitable edge, not for coming into contact with things that might cut them. Two totally different devices, each with their purpose.
  11. Cluck Cluck
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    I've got done straps that if I can find a place to hook them would be perfect of tying down a small tractor or mini excavator, heck I saw a guy with chains on a load of shingles....and straps over his tarp....some people are lost
