Tractor swaying and vibration knocking my mirrors off
Discussion in 'Peterbilt Forum' started by Loaderlou, Sep 15, 2017.
  1. Loaderlou
    Loaderlou Medium Load Member
    342
    131
    Feb 24, 2014
    Hi everyone, I'm experiencing swaying and vibration and I'm wondering if anybody has had that problem and found it was caused by the steering tires.
    poppapump1332 Thanks this.
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Badly cupped and worn ft. tires will shake a/c lines and everything thats bolted on to the truck till its falling off your truck, when it starts shaking is the time to fix it?
  4. Loaderlou
    342
    131
    Feb 24, 2014
    Thanks for the comeback Baha. New tires, centrmatics and shocks going on today. Hoping that will do it. Otherwise I may have to change the steering box. Just wondering if the tires had a slight crown to them if that would make it wander
  5. stayinback
    stayinback Road Train Member
    3,911
    8,256
    Jan 24, 2014
    chicago,il
    please inspect your front axle completely- It can be other factors that contribute to the shaking/vibration you experience-
    A good start is this- Have someone in your truck turning the wheels left and right while you stand outside on the left looking at everything- Make sure your axle isn't "Walking"
  6. xsetra
    xsetra Road Train Member
    5,103
    6,961
    Aug 21, 2011
    Ball joints, mentioned steering box. King pins. Tire balance. Bad belt in tire.
    Not sure about bearings.
    Check your rear axle too. Depends how your vibration is transferred to you.
    Does your steering wheel shake or is it steady?
    Do you feel it in your feet or in your seat?.
    Better mechanics on here than me to help you diagnose.
  7. Loaderlou
    342
    131
    Feb 24, 2014
    Thanks for the comebacks everyone. I will check all of theses suggestions. I'm noticing movement in the front rears front yoke, maybe remove a shim or two? Also the cab was really shaking yesterday at about 65 mph. Front cab bushings are tight but can't tell if the rear mount is loose or worn. All u joints are good. On my front rear, the driver side spring is sitting higher than the passenger side. I can stick my pinky between the top of the spring and the wear pad. If the rear is not pitched properly would that cause vibration?
  8. Bigrayon
    Bigrayon Road Train Member
    1,283
    646
    Aug 16, 2015
    Next time if you look at the tire and sure take it to balance and you will know right away new tires are something else before new tires
  9. Mr. PPS
    Mr. PPS Light Load Member
    85
    70
    Aug 13, 2017
    Deflated airbags did this for me last time.
  10. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    my company truck was doing the same thing snooped around and find a badly cupped steering tire on passenger side.
  11. Loaderlou
    342
    131
    Feb 24, 2014
    Hi Everyone, sorry for the delayed comeback, I've been doing a lot to remedy this, and I think I've got it. New steer and drive tires, which I needed anyway, new front shocks, all new wear pads (46k air trac), centramatics on the steers and a little tweak to get my air ride to proper height, oh and a new drag link. Almost a 100% now. Just waiting for an appointment for an alignment. Thank you all for your help and advise.
    xsetra Thanks this.
