Tractor/ Trailer Braking Help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Chevyho, Oct 29, 2014.
  1. Chevyho
    Chevyho Medium Load Member
    350
    55
    Dec 13, 2013
    I have a tridem end dump pulled with 07 pete 379.. I have been getting some erratic trailer braking and flat spotting on inside of a couple tires on the trailer.. When investigating I noticed after city stop and go traffic my trailer brakes are really hot and my truck brakes are barely warm. Is it normal for the trailer to do most of the braking? When braking it feels like as soon as I touch the brake it puts all the air to the trailer, really hard to make a smooth stop.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    there are LSV valves on newer trucktors-trailers. If trailer is empty - low pressure in air bags and low brake pressure. More load - more brake pressure
    but some trailers got no LSV and overbrake usually
    Chevyho Thanks this.
  4. BeenJammin
    BeenJammin Light Load Member
    256
    118
    Dec 17, 2013
    Google- Phillips quick release Gladhand valve options. You have to reduce the lag time of air release on trailer braking, especially in city driving.
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I think installing and ajusting LSV solves the problem
  6. Chevyho
    350
    55
    Dec 13, 2013
    Ive started searching for a lsv, i think that will be the way to go. If anyone has a link to one please share, I am assuming it just runs off bag pressure.
  7. Bendix Tech Team
    Bendix Tech Team Bobtail Member
    34
    23
    Jul 15, 2014
    if you dont already like ben jammin suggested install some inline quick release valves (bendix pn is 800333)which will help the relase of the trailer brakes and reduce the time it takes for them to release. if youre concerned about pressures put a gauge on your blue glad hand and see if you are getting the same pressure there as one of your brake chambers on the tractor.
  8. Chevyho
    350
    55
    Dec 13, 2013
    Thanks, do the valves install at the glad hands? Put one on service and emergency?
  9. Bendix Tech Team
    34
    23
    Jul 15, 2014
    Yes they do. One end is male the other female so just unthread your glad hand, and put it in between the glad hand and hose. 1/2" NPT both ends
