Tractor Trailer fires
Discussion in 'Truckers News' started by sweetpea, Apr 16, 2014.
  1. sweetpea
    sweetpea Light Load Member
    123
    46
    May 2, 2008
    Glade Hill,VA
    I would like information on any and all truck fires, especially engine fires. I am trying to find out if the DPF system is causing these engine fires. If you just see a truck fire and tell me what road and maybe a town or nearby town I can find out more about it. Thanks in advance
    Sweetpea
  3. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    more often than not truck fires are caused by overheated brakes
    there were not any less fires before DPF systems came along
  4. 1988mustangfan
    1988mustangfan Bobtail Member
    6
    Apr 3, 2014
  5. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Most fires are caused by an electrical short than anything. There is a lot of power feed wiring before it hits a fuse or circuit breaker. I'd say the #1 truck stop fires are from poorly installed inverters. Someone that is not that electrical savvy will run the cables through the floor not thinking about the metal grounded floor rubbing a hole in insulation of the main hot cable over time or might have the wrong size cabling that overheats.
    Other causes could be brakes or a fuel leak. I kind of doubt the DPF system is causing fires. Even if they were stopped up and producing excess heat the system is shielded. You can run a fireplace through a wooden roof with a double insulated stainless steel pipe and not burn the house down. I'm sure the engineers have that part under control. Vibration and corrosion is a truck's enemy.
  6. Cranky Yankee
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    forgot about inverters
    undersized wire probably main culprit there
  7. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    Inverters ... incorrectly wired, and just plain go bad internally ... probably overloaded long-term and the overload protection fails to shut off the inverter and they get hot to the point of being able to ignite things internally or adjacent.
  8. Winkjr
    Winkjr Road Train Member
    1,804
    614
    Oct 18, 2011
    Marlton NJ
    Sweet pea find out what happened in California. They say the truck was on fire before it crashed. Maybe it was the DPF.
  9. sweetpea
    123
    46
    May 2, 2008
    Glade Hill,VA
    One of the companies that made some of the DPF closed their doors and went out of business because the DPF was causing grass fires. Other vehicles that run on diesel are also having fire problems because of the clean air parts put on them. The FedEx truck fire here in VA, the smoke was coming out of the sleeper, it was not a tire fire. I watched this fire from the cameras on VDOT 511 system and the tires were fine, it was the cab. Thanks for all the post and I would love more responses
  10. sweetpea
    123
    46
    May 2, 2008
    Glade Hill,VA
    If your chimney gets stopped up and you continue to burn wood, your chimney and house will catch fire, so it could be the same with the DPF system or other systems for the clean air.
