Trailer brake lights come on with blinker
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by OldeSkool, Mar 5, 2019.
  1. OldeSkool
    OldeSkool Road Train Member
    1,743
    5,047
    Jul 17, 2018
    New Hampshire
    So on my 07 Freightliner Century the trailer brake lights come on when i turn on the left blinker. It does not do it if I turn on the right blinker. I checked my electric cable running to the trailer with a test light and sure enough the brake light prong lights up when I turn on the blinker so has to be on the truck right? Any ideas?
  3. OldeSkool
    1,743
    5,047
    Jul 17, 2018
    New Hampshire
    Also the trailer brake light occasionally stay on after I have let off the pedal for a while. Not sure if that could be connected with it.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,490
    6,540
    Aug 26, 2014
    The first I would most likely blame on the signal switch. Have someone watch the lights while you move the switch handle a little past or before where it stops by itself. If the lights every work correctly it is probably the switch.
    The second I would thank is brake light switch related. There are two of them. Is it possible the plunger under the brake pedal is sticking and holding a little pressure on the system?
    Two different problems at the same time seems odd.
    Working2party and OldeSkool Thank this.
  5. OldeSkool
    1,743
    5,047
    Jul 17, 2018
    New Hampshire
    Thanks Bud!!! You were right on the blinker switch. I'll check the brake light switch when I get time
    BoxCarKidd Thanks this.
  6. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    Check you're trailer ground, sometimes when the trailer's not grounded well the taillights will blink with the signal lights. You can check it by using a jumper between the trailer and the tractor.
    OldeSkool Thanks this.
