Trailer brakes, air issues, no audible leaks when handbreak is on.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MTMAUS, Mar 27, 2023.
  1. MTMAUS
    MTMAUS Light Load Member
    223
    175
    Sep 28, 2019
    Hey, I have a trailer that is having air issues somewhere.
    This trailer used to always take a long time to build air to release the brakes first thing in the morning, but once the air was built it was fine for the rest of the day.
    Now when you have to put on the handbrake (red button) it loses all its air and takes for ever to built air again.
    I cant hear any leaks when the handbrake is on or off, and the dash gauges seem fine for pressure.
    Any ideas on where to start with this one?
    Any help is appreciated.
    Thanks
  3. skallagrime
    skallagrime Road Train Member
    3,856
    9,943
    Apr 10, 2012
    Indiana
    Does it have an auto tire pressure filler? If so, you could have a big enough air leak on a tire that you essentially have to bring that tire pressure up before the tank will stay full...
    Oxbow Thanks this.
  4. MTMAUS
    223
    175
    Sep 28, 2019
    No it doesn't tyre pressure filler
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,491
    6,542
    Aug 26, 2014
    Where does it dump air from when you pull the red knob? Most likely trailer park valve above trailer axles. That means it is defective.
    Slow to release in morning could be the same valve or another restriction.
