Trailer brakes not working
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ParkerFly, Oct 12, 2017.
  1. ParkerFly
    ParkerFly Bobtail Member
    45
    4
    Apr 11, 2012
    Tennessee
    I just realized that my trailer brakes aren't working on my trailer. They release fine, but don't do anything when I hit the pedal or the hand valve in the truck. Can someone point me toward what to check first? I won't have a lot of time to work on it tomorrow but obviously need to get it fixed. Thanks for any help,
    Justin
  3. kemosabi49
    10,449
    44,486
    Jan 13, 2013
    SW Arkansas
    How old is the trailer? You should have automatic slack adjusters if it's a 94 or new trailer. But even they can screw up though having all screw up at the same time is odd. Earlier than 94 may have manual slack adjusters. Get a 9/16 wrench and adjust them. You need to get this fixed before you run it or you could kill someone.
    strollinruss Thanks this.
  4. ParkerFly
    45
    4
    Apr 11, 2012
    Tennessee
    It's not that they're out of adjustment (they're not), they don't even try to apply when I send air back there. It's like air isn't even getting to them. When I pull the hand brake and then let off it barely exhausts any air at all.
    Eli S. Thanks this.
  5. strollinruss
    strollinruss Road Train Member
    1,366
    1,699
    Jun 5, 2012
    Montgomery, TX
    Pull your blue line and make sure it's working when you apply hand brake. Trash could have got in air line on trailer too
  6. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Get under trailer and find service brake valve its the one that the brake lines lead to small chamber close to slack adj. and find part num. off of it and buy a new valve not rebuilt one?
  7. 6wheeler
    6wheeler Road Train Member
    2,696
    4,772
    Aug 30, 2009
    One of my trailers did that. Its a thing with a plunger that get jammed up. Kind of like a brokern totlet bowl. If you get air pressure from the blue line when you step on the brakes then its that value where all the airlines connect to under the trailer.
  8. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Step 1, release the trailer brakes, then remove the blue gladhand from the tractor. Apply the service brakes and make sure that you are getting service air from the tractor. Then you'll know if it's a tractor or trailer issue.
    If the tractor is not giving service air to the trailer, start by checking the tractor protection valve.
    If the tractor is giving service air, check that the trailer air tanks have pressure. The spring brakes releasing does not mean you have air pressure in the trailer tanks. If the check valve is stuck in the spring brake release valve, it will release the brakes, but not fill the tanks. If the tanks are empty, it's most likely a sticking check valve in the spring brake release valve.
    If the tanks have pressure, then pull the service line off the trailer relay valve (the one that goes to the blue gladhand) and step in the brakes to make sure that the line is clear and putting pressure to the relay valve. If the line is clear, you most likely have a bad relay valve.
    Wondey, circle h, Opendeckin and 5 others Thank this.
  9. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    Would this cause it to take a very long time to release the brakes after popping the red button even for a minute?
  10. habfleet
    habfleet Light Load Member
    163
    23
    Feb 5, 2012
    elwood nj
  11. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    I'n not 100% sure what you're asking. When you push in the red button, the spring brakes take a min to release? If the check valve is stuck closed (not filling the trailer tanks at all), then the spring brakes will release normally (assuming that the check valve is the only issue with the spring brake release valve).
    Think of the spring brake valve being a Tee. Air from the red button goes in the middle, one side goes to the spring brake chambers and the other side goes to the air tanks (through a check valve). So a stuck closed check valve will not stop the spring brakes from releasing. If air cannot get past the check valve, it will just build up pressure in the line and brake chamber to release the brakes (leaving the tanks empty).
    That check valve can also stick open (or partially open). In that case, the trailer tanks will drain out when the brakes are set. Releasing the spring brakes will be delayed if the trailer tanks need to fill (this is true of any leak that drains the tanks). That is because all the air is going into the tanks and it the whole system builds pressure together.
