Trailer docking question
Discussion in 'Questions From New Drivers' started by wildbill123, Apr 16, 2011.
  1. wildbill123
    wildbill123 Heavy Load Member
    713
    322
    Jan 31, 2009
    SE,MI
    My question has to do with bumping the dock. When you bump the dock with the trailer and set the brakes I know the trailer will move away from the dock an inch or two after about a minute or so. Then I release the brakes and bump it back against the dock again. Sometimes the trailer doesn't pull away from the dock until it's been sitting for ten minutes or so.
    Is there a way to make sure the air has bled out so I know the trailer is not going to move ? Sometimes I'll set and release two or three times to try and make sure it's not going to move, only to find out ten minutes later it moved anyway.
  3. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    if you can dump the air to the trailer--do that--then bump the dock
  4. wildbill123
    713
    322
    Jan 31, 2009
    SE,MI
    Are you talking about the air suspension control ? I usually flip the air suspension control and lower the trailer before unhooking from it.
  5. canuck in da truck
    4,352
    2,601
    Aug 6, 2010
    western pa
    yes--the trailer air ride--if you dump the air first--then back into the dock--the trailer wont walk away from the dock
    with an auto dump--the trailer will generally pull away from the dock as the air comes out of the suspension
    not the suspension switch in the cab--it is a seperate one on the trailer--some have them--some dont
    wildbill123 Thanks this.
  6. Sequoia
    Sequoia Road Train Member
    2,692
    1,794
    Dec 4, 2010
    Tampa Bay, FL
    If it's an issue, why not just disconnect the air lines?
  7. wildbill123
    713
    322
    Jan 31, 2009
    SE,MI
    The trailers I pull don't have a separate switch.
  8. wildbill123
    713
    322
    Jan 31, 2009
    SE,MI
    It still takes time for the air to bleed out. I dropped a trailer in a dock and made sure it was still butted up against it. Ten minutes later it was two inches from the dock and they were complaining about it. That's why I started looking at it a little closer.
  9. Bent Wrench
    Bent Wrench Medium Load Member
    588
    205
    Aug 11, 2009
    Cornholio, OR
    You could set the trailer brakes then release the truck brakes and put pressure against the dock, then set truck brakes with pressure held.?
  10. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    put some crazy glue on the back of the trailer???
    Mikeeee
  11. Lantern
    Lantern Road Train Member
    1,800
    824
    Mar 8, 2011
    Deliverin Soda
    This might be a great suggestion. But the removal process might be a pain!
