Trailer dog-legging because the brakes
Discussion in 'Experienced Truckers' Advice' started by Jack carg, Apr 11, 2019.
  1. Jack carg
    Jack carg Bobtail Member
    20
    7
    Mar 1, 2019
    Hi guys
    I have 2013 trailer and trailer always go to the right, I took it to the shop and replace the spring break valve because was leaking also done alignment , but I still have the same problem, I did an inspection of the brake system and found out the brake shoe touching the drum a little bit, then I adjusted the slack to make off, then I continue drive the trailer drive straight and my full mileages went up from 6.5 to 8 mpg but because I have auto slack adjuster , the problem come back again
    Now Im wonder do i have bad slack adjuster or brake chamber or what, please guys, I need help
  3. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    A dragging brake won't cause the trailer to "dog leg" and if it was dragging enough to drop your mileage it would catch fire, you have another problem; possibly a broken suspension component or extremely worn bushings.
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,133
    Mar 5, 2016
    White County, Arkansas
    You also have another problem.
    If you are legally certified to adjust brakes on 18 wheelers and carry such a card allowing you to say at the scales to do it... then great. IF you do not possess this training, then only a certified mechanic can go under and touch those braking systems and whatever else as necessary to fix the dog leg.
    The trailer must not be towed or driven until the dogleg problem is fixed. There could be a thousand sources of that problem. A dab of brake show isnt going to fix it.
    Numb and Lepton1 Thank this.
  5. snowwy
    snowwy Road Train Member
    20,535
    13,271
    Jul 6, 2009
    Adjust all 4 brakes and see what happens. Loosening ONE is absurd.
  6. Brandt
    Brandt Road Train Member
    4,475
    6,106
    Sep 17, 2012
    Ever who did the trailer alignment did a bad job. It's not a brake related
  7. Ridgeline
    22,305
    115,355
    Yes you have a bad adjuster, get it replaced or better yet get ALL OF THEM replaced at the same time.
    JoeyJunk and x1Heavy Thank this.
  8. 201
    201 Road Train Member
    12,209
    24,908
    Apr 16, 2014
    high plains colorado
    DOG TRACK, it's dog tracking,,,ugh,, besides, I have no idea what this person is trying to tell us.:dontknow:
    x1Heavy Thanks this.
  9. x1Heavy
    34,017
    42,133
    Mar 5, 2016
    I don't either believe it or not. Im just being very cautious here.
    Ive had a mess of onery trailers in my time but those are usually idiot proof problems like outright bent rails and such.
    Lepton1 and 201 Thank this.
