Trailer hub oil leak, will I get written up on inspection? (picture)
Discussion in 'Experienced Truckers' Advice' started by silverspur, Jul 3, 2022.
  1. 48Packard
    48Packard Ol' Two-stop Shag!
    8,348
    9,864
    Apr 19, 2009
    Could be anywhere
    I had forgotten about this. Good call!
    nikmirbre and D.Tibbitt Thank this.
  3. silverspur
    silverspur Road Train Member
    1,192
    4,416
    Sep 26, 2012
    I just happened to be at a Petro and checked. They don't have any. It took several minutes to explain what it is used for. And then they have to hold it in their hand, possess it and take it with them while I stand there waiting.
    Trying to avoid too many of these situations at my age.
  4. silverspur
    1,192
    4,416
    Sep 26, 2012
    Three of them have pin holes. They're not plugged. One doesn't. I just had the trailer washed. I'll keep an eye on it.
  5. 062
    062 Road Train Member
    5,852
    31,733
    Oct 20, 2013
    I’m surprised that they didn’t have one. I’m not surprised they didn’t have a clue.
    That’s why I said to take it with you.
  6. MAMservices
    MAMservices Light Load Member
    275
    1,701
    Aug 9, 2021
    Another problem with these type oilers, is the plastic “window” the plug fits into, with age, have a bunch of little cracks come in them. Makes em look hazy like old head light lenses, and oil migrates out of em over time enough to make a little mess. When ya wash em look to see if they are nice and clear. If not change em.
  7. SmallPackage
    4,524
    13,618
    Dec 20, 2019
    Marion Texas
    Spray it with brake clean and wipe it off with rag. As long as its moving it may not leak any more. It probably won’t leak again until the trailer sits for a long time again.
    Diesel Dave and D.Tibbitt Thank this.
  8. D.Tibbitt
    130,560
    Ok so just replace them. The plastic window, new plug and gasket is like 20 bucks or less at any dealership.
  9. shatteredsquare
    shatteredsquare Road Train Member
    1,363
    1,774
    May 23, 2014
    middle dirt
    no
    because i only drive past closed scales
  10. silverspur
    1,192
    4,416
    Sep 26, 2012
    This is not a one and done. It's at least every other trailer I take off the yard. My present trailer has 3. I will be on light duty for a couple months before end of year and might volunteer to replace them in trailers then. Most of plastic windows are bad. Some have hard plastic caps instead of the rubber ones
  11. armo
    armo Light Load Member
    274
    289
    Jun 16, 2022
    in Cal chp will give you warning, if oil drops then out if service.
    in NM they will write you Brocken equipment and may put out of service.
    in NV maybe just warning
    in AZ maybe warning
    New guys from MO will put you out of service and will write for sure ..
    silverspur Thanks this.
