Trailer length and maneuverability
Discussion in 'Flatbed Trucking Forum' started by Bdog, Nov 27, 2015.
  1. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    Up until now the extent of my experience driving a tractor trailer was taking my road test. My class A driving experience has been driving dump trucks and hauling backhoes on pintle trailers.
    I now have some equipment I need to move all over the country and a tractor trailer is the most reasonable solution. We don't go to any cities just rural farms and ranches but some of them can be tight getting into.
    I think I have worked out a trade on a Pete 379 and am working on choosing a trailer. My load will be no more than 25k and it would fit in 35' of length. It could be a drop deck with 10' of it going on the upper deck and 25' of it on the main deck.
    I don't really have any plans of hauling other people's stuff or needing flexibility for other loads.
    Now the background info is there my used trailer searches are pulling up a whole ton of 53' trailers and not a lot of shorter ones. A 53' would certainly work but I wonder how much harder maneuvering it would be vs a trailer that was say 10' shorter. Is it a huge difference or will I get the hang of a 53?
    I would like to find a trailer in the 20k or less price range.
  3. Arky
    Arky Heavy Load Member
    853
    586
    Jun 7, 2013
    Getting the hang of it wouldn't be much of deal, getting it into out of some of the county roads farm roads is a toss up unless you know they were built for t/t to navigate them.
    The shorter the trailer, the less it will off track on a tight turn. You should be able to find plenty of 48' flats and steps. There are shorter trailers than that as well. Truckpaper.Com is always a good place to do research. They do have searchable trailer section.
    G13Tomcat Thanks this.
  4. johndeere4020
    8,522
    119,291
    Jan 1, 2010
    What is the weight you want to haul?
  5. Arky
    853
    586
    Jun 7, 2013
    I think it could be done with a gooseneck even? Borderline?
  6. Bdog
    1,057
    877
    Nov 6, 2014
    No more than 25k of equipment on the trailer.
  7. Bdog
    1,057
    877
    Nov 6, 2014
    If I split it on two trailers maybe but one machine is 18k by itself. That along with a 7k trailer is a lot of load for a pickup.
  8. Arky
    853
    586
    Jun 7, 2013
    Single axle class 7 truck with 36-40 ft gooseneck? Could a dually handle it?
  9. Arky
    853
    586
    Jun 7, 2013
  10. Arky
    853
    586
    Jun 7, 2013
  11. Alberta trucker
    Alberta trucker Bobtail Member
    36
    28
    Nov 16, 2015
    Leduc, Alberta
    I use an International Workstar with a 208" wheelbase, N13 engine, 14k steer and 23k drive axle, pulling a 40' hydraulic dovetail gooseneck. I haul rental equipment all over western canada and my usual load weight is 22-27,000 pounds. I have the extended cab with the bunk option.
    Another driver I know does the same thing with a 34' gooseneck and a 07 international 8600 day cab but he only runs local loads.
    I would say get a Freightliner M2 crew cab with the bunk, a cummins 8.3l, a nice deck on it and the gooseneck.
