Trailer lift axle - ROI
Discussion in 'Experienced Truckers' Advice' started by spindrift, Oct 8, 2019.
  1. spindrift
    spindrift Road Train Member
    3,233
    12,905
    Dec 2, 2014
    Texas
    Rarely do I see trailer's with the forward lift axle. Got me wondering if the return on investment is worth the initial cost of that set-up. Have no idea as to what that kind of trailer would cost, but it seems that fuel savings and reduced tire replacement could be significant over the life of the trailer. Since I see so few of them, does that mean that this set-up is extremely expensive?
    D.Tibbitt Thanks this.
  3. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    If a guy ran empty a lot, it would probably be worth it just in fuel savings over the long haul.
    I don't know what the initial cost is though.
  4. spindrift
    3,233
    12,905
    Dec 2, 2014
    Texas
    Right...you would think tanker outfits would embrace it under those circumstances.
  5. Tug Toy
    Tug Toy Road Train Member
    6,939
    72,583
    Jul 4, 2015
    Corn field
    The hard part kit is $500.00 the valve is about $150.00 plus installation.
    I run empty %20 of the time and could probably run light enough to use it another %20 of the time.
    I haven’t put one on my spread flat but if I buy a new one it will have one. And disk brakes.
    Don’t know that it really saves any fuel but guessing it saves on tires on a speed axle. also can save you a little on tolls too.
    Coffey, spindrift and JonJon78 Thank this.
  6. snowwy
    snowwy Road Train Member
    20,536
    13,271
    Jul 6, 2009
    I've been noticing them more and more lately. You'll probably start seeing them more also. As people start using them.
    spindrift Thanks this.
  7. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    Looking at used flatbed trailers there is as small premium if it has a lift axle.
  8. Fold_Moiler
    Fold_Moiler Road Train Member
    1,926
    3,528
    Mar 17, 2017
    I’d for sure have it if I owned a spread axle or 3 axle trailer. A lot of guys have them here in all variations.
  9. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    I see them every day. I put a manual dump on the rear axle of my spread for crab walking into/out of impossible quarries and drop sites. Started strapping the rear axle up in the air just to see and it was up to .75mpg but was easy to flat spot the hanging tires. Glided real good.
    Very basic metal skills can build an air lift axle kit. Nothing special about it.
    FlaSwampRat and spindrift Thank this.
  10. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    They're catching on with the bigger private fleets near me. Pepsico has a lot of their new dry-vans with auto-lift front tandem axle, for example. Also, a large portion of the O/O flatbedders, potato haulers, tankers, and dumps are going to one or more lift axle, often leaving only one axle on the ground running empty.
  11. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    My old flat deck company had manual air-lifts on almost every newer aluminum high-boy (and pneumatic for that matter). Boss said they cost over $7000 CAD to install and got really upset if he saw a driver running empty with them down.
    Most were front lifts on tridems, a handful were centre lifts on tridems. All the quads had center lift and obviously the fourth middle axle. B-trains were front lift or front/rear lift on the leads and front lifts on the pups.
    Lots and lots of dry/liquid bulk outfits use them, so there must be some added benefit (since they are heavier, that would impact their total payload space). I personally can't see tire wear impacting the ROI that much, but what do I know, I don't have numbers to run, I just drive the truck.
