Trailer light problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jackhicks46290, Jan 28, 2016.
  1. jackhicks46290
    jackhicks46290 Bobtail Member
    8
    Jan 13, 2016
    On my 8600 the turn signals work fine until I turn on my marker lights, they are constant. Same way coming out of the fuse boxe under the hood. Please help...
  3. sidrambill
    sidrambill Light Load Member
    70
    51
    Feb 5, 2015
    lakeland, fl.
    You have a bad socket some where. Probably full of water. Stay out of the wiring and the fuse box. Start with tractor tail lights. Don't start rewiring it's something simple.
  4. AModelCat
    161,512
    Ok so your title says trailer light problems but you don't mention if this problem occurs with or without the trailer hooked up. If it only does it with the trailer hooked up the problem is most likely in the trailer.
  5. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    Your ground on the trailer isn't making contact. If you can spread it gently with a flathead then do it.
  6. RidinDirty11
    RidinDirty11 Light Load Member
    114
    103
    Aug 20, 2015
    You most likely have a bad ground. I have also seen corrosion in connections for the trailer lights and turn signal lights back feed from corrosion. Used to take me days to trace this crap down, but I bought this lead set called a load pro, and it actually works. You could make one, but I am too lazy. just load the circuit, and you will find your corrosion easily by the voltage drop.
  7. AModelCat
    161,512
    I usually just use a my Fluke multimeter. Hasn't failed me yet.
