Trailer light wigging out
Discussion in 'Expediter and Hot Shot Trucking Forum' started by DouletTheDriver, Feb 7, 2020.
  1. DouletTheDriver
    DouletTheDriver Light Load Member
    62
    43
    Sep 3, 2019
    Katy, TX (Houston)
    Having a weird situation with the trailer.
    The driver side amber turn signal doesn't turn on with every other light, but it works/blinks once the turn signal is activated.
    The passenger side turns on, stays on, and blinks when signal is activated.
    Have you experienced this before?
    Currently confused on which one working correctly!
  2. Slay
    Slay Light Load Member
    113
    108
    Jan 7, 2015
    The passenger side is working correctly. Remove the light from the pass side and replace the driver side. If it works go buy another light.
  3. npok
    npok Light Load Member
    148
    152
    Sep 26, 2015
    And if it doesn't work, check the plugs, terminals, & power wire.
    There should be a ground, power, and a blinker wire.
    singlescrewshaker Thanks this.
  4. DouletTheDriver
    62
    43
    Sep 3, 2019
    Katy, TX (Houston)
    Well now that it’s dark and I made a left turn, I noticed that when I apply the brakes, the light turns on. So I’m thinking the bulb is good and it’s an electrical issue.
    I tried the rear port on the truck, still nothing so definitely the trailer
    I’ll try to figure it out over the weekend.
  5. singlescrewshaker
    1,312
    10,128
    Dec 31, 2017
    Palmgetto, FL
    Alot of small trailers are just wired that way. The manufacturer just ties that side turn signal into the same circuit as the brake, turn, tail light. My LoadMax was the same way. Hit the brakes, & the side blinkers light up solid amber in sync with the brake lights.. LoL
    If they are not led, the dim filament (marker) is probably just burned out. If they are led, you may just have a defective light, wiring, or bad connection..
    Do what @Slay said & swap lights with known working one to see if it's just the light fixture itself..
  6. rccarlson22
    rccarlson22 Light Load Member
    109
    112
    Aug 27, 2019
    X2 the amber lights on the side shine solid when I apply the brakes
  7. DouletTheDriver
    62
    43
    Sep 3, 2019
    Katy, TX (Houston)
    Yeah I have the Load trail. It was the light. Switched it out, now they both are always on.
    I don’t like it because it makes the blinking not very noticeable when looking at it.
  • Draft saved Draft deleted
