Trailer mechanic switched right brake light and turn signal
Discussion in 'Experienced Truckers' Advice' started by JC1971, Jul 15, 2023.
  1. JC1971
    JC1971 Road Train Member
    2,666
    9,741
    Jul 29, 2013
    L.A.
    Does it matter besides looks or is there a law that says it has to be in the correct place? The lights have a retaining ring riveted on so I can't fix it.
  3. xsetra
    xsetra Road Train Member
    5,114
    6,981
    Aug 21, 2011
    no, I don't think it matters. Just needs to be back there. Can you reach the pigtails from underneath and behind. Switch those connectors.
    JC1971 Thanks this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,718
    9,032
    Jul 12, 2017
    I would say both sides should be the same. Leaving them different left to right is just asking for trouble. But technically as long as they work…….
    JC1971 Thanks this.
  5. JC1971
    2,666
    9,741
    Jul 29, 2013
    L.A.
    No, it looks like everything is tucked inside the metal frame from what I can see. I don't see how you can access the wire harness without pulling the lights out.
  6. kemosabi49
    10,663
    45,730
    Jan 13, 2013
    SW Arkansas
    Nothing in the regs say that the signals have to be outside and the brake lights inside. In fact the regs do not even say you need four taillights.
    Technically, you could have only one light on each side with a brake/signal/taillight combo and be legal.
    § 393.11 Lamps and reflective devices
    Bean Jr. and JC1971 Thank this.
  7. IH9300SBA
    IH9300SBA Road Train Member
    2,314
    22,435
    Feb 26, 2021
    Take a small flat screwdriver and pry them out. There's usually three small raised ribs holding them in and they will pop out if you're careful.
  8. abyliks
    abyliks Road Train Member
    3,888
    9,091
    May 2, 2010
    ludlow MA
    most brake/signals are on different circuits which is why there is 4
  9. SmallPackage
    5,460
    17,361
    Dec 20, 2019
    Marion Texas
    Also Make sure that the turns are correctly wired for the side they are on. If you are in the habit of checking them with the fourway lever you may never know that your trailer blinks left when the tractor blinks right. Seen this way to many times when someone replaces a bad 7 pin j-socket.
    kemosabi49 Thanks this.
