I've got a spread axle trailer that has intermittent problems with the air bags being overextended. I've noticed it happens often after unloading a heavy load from the trailer. If I dump the rear axle so the arm on the valve goes back down to the fill position, it will operate and cut out normally when I refill the bags. I've replaced the leveling valve, but it didn't correct the issue. The last time it happened, the bags stayed at max height when I dumped them, almost as if something is getting hung up somewhere. I jacked up the rear axle, and it corrected itself when I lowered it.
What are some of the possible causes and solutions?
Trailer not lowering ride height while exhausting air
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by loudtom, Dec 22, 2020.
