Trailer overhang
Discussion in 'Experienced Truckers' Advice' started by mitmaks, Jan 25, 2025.
  1. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    How many feet am I allowed to overhang off the back of 48' trailer and 53'? Is it up to 4 and then oversize permits are needed?
  3. Long FLD
    Long FLD Road Train Member
    12,832
    53,689
    Mar 4, 2015
    Depends on the state and how long your trailer is and how long the material is. A couple examples, WA doesn’t allow overhang on a 53’ without a permit, WY requires a permit for material over 60’.
    Ruthless, brian991219 and D.Tibbitt Thank this.
  4. D.Tibbitt
    156,846
    What states are u running thru? And what material u hauling
    Some states are 4. Some are none. Some are 10ft
  5. mitmaks
    2,586
    2,102
    May 16, 2014
    It's load of pipe n coming from WA to TX.
    D.Tibbitt Thanks this.
  6. blairandgretchen
    13,926
    76,505
    Dec 9, 2011
    South west Missouri
    What is the product length, trailer length and overall (front of truck to end of load) ?
    What states?
    TX for example is legal with 57’ trailer/load. Also OK.
  7. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    For permits. States are different. You're probably safe up to the 4 foot. Since that would put you at 52 feet. Less then a 53 foot trailer.
    The flags and banners themselves.
    Anything over 4 feet. Lighting on the rear if driving in the dark. Wyoming requires lighting on the sides of overhang also. Least they made me light the sides.
    Overhang as much as you can on the front. To minimize rear overhang.
    Hopefully you have a 4x4 to lift the front up if needed. If you can keep the rear overhang under 4 feet. You shouldn't need flags and banners.
    That's for a 48 trailer.
    mitmaks Thanks this.
