My tractor is leaking out the exhaust port when one of the trailers is hooked up during when performing an applied leakage test (truck in gear engine off, valves in, service brake applied).
I hear absolutely no air loss anywhere but the exhaust port on the Bendix TP5, and it leaks a good amount.
However, with my other trailer, the tractor performs the test perfect with no leaks.
What would cause this? I am confused since I found no leaks on the trailer..
Thank you
Trailer protection valve leaking with one of the trailers only
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by montrose818, Jan 20, 2020.
It's probably a bad air can on the trailer back feeding through the TP Valve. Try crawling under the trailer with a pair of vice grips and pinch off one service line at a time on each of the cans until you find it.
stillwurkin Thanks this. -
Changed both cans, nada. I should have tested first but the cans looked old and were cheap enough to replace as preventive maintenance.
It ended up being the relay valve.
Thank you!Mike250rs, Swine hauler and jsnell Thank this. -
Was it the atr 6 traction relay valve on your tractor or was it a relay valve on the trailer. I have the same problem
It would have been on the trailer.
Its allowing air to back feed to the truck.
