Trailer Tire Inflation System...Ever seen them air up a tire broken loose from wheel?
Discussion in 'Experienced Truckers' Advice' started by oneperfectrun, Jan 4, 2013.
  1. oneperfectrun
    oneperfectrun Light Load Member
    131
    47
    Dec 18, 2010
    Fulton, MS
    As the title says, have you ever seen a trailer tire inflation system air up a tire, that was broken loose from the rim, while the trailer was in transit? I'm asking this from a discussion on another forum.
    Back several years ago when the company I worked for at the time first started getting trailers with tire inflation systems a friend told me that he had a tire broken loose from the rim that was seated and aired up when he got to destination. I knew the guy wouldn't lie to me but I still thought to myself, I don't know if I believe that or not! Later on I had the same experience. Since then I've had it happen approx 4-5 more times.
    I guess somehow when in motion the tire spreads and seats enough to take air. Not exactly sure how it happens.
    Just wondering if anyone else here has had the same experience.
  3. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    It could happen somehow if a bead does seal along the way.
  4. Moosetek13
    Moosetek13 Road Train Member
    14,656
    18,402
    Nov 1, 2010
    Burnsville, MN
    Probably the same way a tire will seal to the rim as air is being supplied in a tire shop.
  5. Chucktaylor
    Chucktaylor Road Train Member
    1,065
    640
    Sep 26, 2012
    It's happened to me. Nice suprise
    oneperfectrun Thanks this.
  6. dude6710
    2,162
    622
    Mar 26, 2010
    MN
    how? Mindblown!!!!
  7. oneperfectrun
    131
    47
    Dec 18, 2010
    Fulton, MS
    I was really surprised the first time I personally saw that it did seat and inflate the tire. Just hard to imagine how it spreads the tire enough to seal enough to take air.
    I've wondered several times, with the fact that this happens, why the tire was broken loose from the wheel to start with.
  8. Moosetek13
    14,656
    18,402
    Nov 1, 2010
    Burnsville, MN
    It was probably low air pressure.
  9. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Sounds kinda like the CTIS system some of the vehicles in the Army used. Although I don't recall ever seeing that exact thing happen. When I saw the title, I thought at first you were talking about a bead seater for when you were replacing a tire on a rim. Ether is faster, though.
  10. snowwy
    snowwy Road Train Member
    20,537
    13,274
    Jul 6, 2009
    how does the tire go flat to begin with??? in order to start pumping.
    isn't that the systems job is to keep the tire from going flat in the first place.
  11. Noggin
    Noggin Road Train Member
    2,494
    977
    Apr 10, 2011
    Houston, TX
    if the trailer brakes are set, there is no air flow to go through the system, so no inflation
