trailer
Discussion in 'Heavy Haul Trucking Forum' started by zinita17601, Mar 27, 2014.
  1. zinita17601
    zinita17601 Road Train Member
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    im thinking about buying an rgn,what i should be looking for? make,specs etc.thank you
  3. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    what are you looking to haul with it? There are tons of options that work for many different things. Where do you primarily haul? What weights do you plan to haul?
  4. passingthru69
    How big is your wallet?
    jorlee and MJ1657 Thank this.
  5. jorlee
    jorlee Light Load Member
    197
    83
    Feb 17, 2007
    ND
    How big (specs rears, trans, engine, axles etc) is your truck you plan on pulling it with?
  6. zinita17601
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    well im looking to spend 40 or 50 k.my truck is not set up for heavy haul and i plan to run northeast,midwest and southeast.theres few ports around where i live so i plan to haul equipment maybe up to 50,000 lbs.
  7. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,119
    May 19, 2011
    A two axle will be more than enough for you then.
