Trailerbrake.question
Discussion in 'Ask An Owner Operator' started by gerardo1961, Oct 22, 2013.
  1. gerardo1961
    gerardo1961 Road Train Member
    1,746
    613
    Feb 21, 2010
    Miami
    Hi,i have a delivery on a ramp,and everything is with water(min 1 feet) covered.i dont like do drive to this ramp and unload.iam thinking this is maybe bad for the brakes from the trailer.unloadtime min1.5 hrs.what you thing you about this
  3. puncher
    puncher Medium Load Member
    540
    358
    Feb 12, 2010
    Tn.
    I've had to back into docks with up to 2 feet of water, and while I don't like it I've never had any brake problems, but I do keep my trailer greased. If the water is over the hub I would check hub oil in case one of the rubber plugs were to leak.
    Cetane+, Ezrider_48501 and gerardo1961 Thank this.
  4. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Is it salt water or rain water? If salt water from a flood i would never back into it. If its just rain water, go for it but proceed with caution. Just make sure your brakes are good before you leave, and do a few quick stops to dry um out.
    puncher Thanks this.
  5. Lostkeys
    Lostkeys Heavy Load Member
    903
    6,243
    Jan 8, 2011
    Archbold,OH
    I once backed into a flooded dock. The water was over the hubs. My greased packed hubs filled with water...cost me about $500 to have all the hubs cleaned out.
  6. vanapagan
    vanapagan Light Load Member
    75
    53
    Apr 29, 2013
    Merrick, NY
    Stagnant standing water is a health hazard that the property owner must address. Not only does it allow mosquitos to breed but a flooded truck dock is also a garbage catch all. Additionally, there have been several instances where employees have waded into puddles to service/inspect equipment only to be electrocuted. If you read your own carrier contracts you will most likely find some verbiage regarding the duties of the receiver including loading dock specifications and workplace safety. A flooded/poorly maintained receiving dock is most likely a breach of the shipping contract by the receiver. I am not a lawyer but I have dealt with lots of contracts and contractual disputes regarding shipping and receiving for a very large cosmetics firm (The Estee Lauder Companies) in order to support its shipping/receiving system.
    baha and Lady K Thank this.
  7. snowwy
    snowwy Road Train Member
    20,563
    13,287
    Jul 6, 2009
    backing into a swimming pool. isn't any different then dragging trailer in a shower. everything gets wet either way.
    but, i wouldn't want my hubs submerged.
  8. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    Chances are if they filled that fast and with significant amount of water, it came in thru the vent hose of the axle housing.
    Whatever the case, $500 to clean it out is not something anyone desires.
    Edit: As far as vent hose, I had tractor differentials/axles on my mind. I guess because I had a tractor parked where it later flooded past the vent line, and took water in thru there.
  9. heyns57
    heyns57 Road Train Member
    2,209
    1,011
    Dec 30, 2006
    near Kalamazoo Speedway
    Years ago, I drove city delivery with a "cab-forward" day cab. The truck had a below-the-frame muffler with a vertical exhaust stack up the back of the cab. After loading for about fifteen minutes in a flooded ramp, I cranked the engine and powered up the ramp. You guessed it. Soot and water were blasted out of the stack only to settle on the employees cars. I departed in a hurry.
  10. sixthgear11
    sixthgear11 Light Load Member
    197
    192
    Sep 24, 2011
    myrtle beach, sc
    even if its not high enough to flood your hubs, if its high enough to reach the drums, you wanna make sure you're truck had a good while to cool the brakes... you dont wanna roll HOT drums into cold water.
  11. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    if your drums are hot enough that water is going to damage them you're not driving your truck right.
    Hammer166, heyns57 and Cetane+ Thank this.
