Trannie problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Nitemare13, Jun 10, 2018.
  1. Nitemare13
    Nitemare13 Light Load Member
    205
    199
    Feb 24, 2014
    Hudson, Fl
    2012 pete 386 13 speed eaton.
    Last night outta the blue it started to make loud noises. Sounds like bolts in a cement mixer. Temp got up to 240ish. Pulled over immediately and let it cool down. Same thing bone cold today. I thinking bad bearings.
  3. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    Noise+heat=$ At this point, opening it up would be step one. I out can try to wiggle the drive shaft to see if it is the pinion gear bearing, or jack up that axle and turn the wheels to hear/ feel something there, but it's all going to be something ugly inside. Drain the grease out and indentify the pieces of schrapnel that come out.
    Dino soar Thanks this.
  4. Don't drive any further.
    do like A5 said. cut open a clean dry gallon water jug. pull that plug and see the gold mine dump out.
    Start looking for another 13sp now.
  5. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    Trans is toast. R&R.
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Look at your air bags to see if they are all the way up, that can make sounds like the end of all?
    Dino soar and Tug Toy Thank this.
  7. Tug Toy
    Tug Toy Road Train Member
    7,022
    73,603
    Jul 4, 2015
    Corn field
    This!!!! First thing to check. Sounds real bad if you leveling valve goes bad!
    Odds are you got other issues though.
  8. Nitemare13
    205
    199
    Feb 24, 2014
    Hudson, Fl
    Sorry guys, Update: Trans was bad. I drove 40 miles to loves to buy trans fluid. Only to find out it was full. Found a trans shop close by 1/2 mile. Next morning I drove to, well tried to drive there but boom it blew up. Had to be towed. Out the door $4786.81 plus 400 tow fee.
    Heavyd Thanks this.
  9. A5¢
    389
    544
    Oct 30, 2017
    The joys of trailer truckin'!
