Tranny grinds when shifting from low to high gears??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Nestor, Mar 28, 2016.
  1. Nestor
    Nestor Light Load Member
    160
    23
    Oct 21, 2015
    Hey I was wondering if anyone can help me. So I recently bought a day cab tractor. It has a eaton fuller ten speed. I noticed that when I'm shifting from the low gears to the high gears it grinds pretty bad. I pre select the gear so I put to the splitter in the top position before I go to high gear. Also it grinds when I'm going to a stop and put splitter down. Any one know what this is. Thanks for our help
  3. stayinback
    stayinback Road Train Member
    3,911
    8,255
    Jan 24, 2014
    chicago,il
    Mine does the same, I just ignored for lets say the last 10 years now.... Mine only grinds when I put the splitter Down
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,420
    6,435
    Aug 26, 2014
    Search- top right box. It's there.
  5. Nestor
    160
    23
    Oct 21, 2015
    What do you mean
  6. Nestor
    160
    23
    Oct 21, 2015
    Why is that do you know ??
  7. lester
    2,918
    7,867
    Jan 2, 2012
    NW, Iowa
    Synchronizer I'd bet.
    AModelCat Thanks this.
  8. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    My 13 spd once in a blue moon will grind or make a gear clash noise when going from low to high. It certainly isn't consistent as I can do whole trips at a time and not experience the noise and it only does it from low to high never high to low.
    It's been doing this 10 + years as well. My truck doesn't see high annual mileage so it sounds like you are experiencing advanced symptoms of what mine has.
    Hope someone has a common cause for this, I'd like to fix it before it gets to where you are.
  9. kynsilok
    kynsilok Bobtail Member
    24
    5
    Jun 10, 2014
    Many trucks do that on those 19 and 13 speeds, it gets worse over time, last time I asked my mechanic said it was the slpitter valve.
  10. clausland
    clausland Road Train Member
    1,933
    11,067
    Dec 5, 2014
    North Woods
    Check the filter on the splitter valve, might be blocked somewhat...
  11. Nestor
    160
    23
    Oct 21, 2015
    Ok so talked to the mechanic he said its the syncro. There's two of them one from low to high and one is high to low. Wich ever is grinding replace. But checking air pressure to splitter valve and checking filter on splitter to see if it's blocked like clausland said might be a good idea before I get them replaced. Thanks for your guys help this site is awesome!
    Wumbo Jumbo Thanks this.
