trans removal
Discussion in 'Trucks [ Eighteen Wheelers ]' started by digger22, Sep 20, 2014.
  1. digger22
    digger22 Bobtail Member
    Tips for removing trans
  3. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    Have a good trans jack, mark your airlines. The rest is pretty easy if there is no PTO, air tanks, crossmembers ect to deal with.
  4. carolinacrazyhorse
    carolinacrazyhorse Bobtail Member
    35
    26
    Mar 13, 2014
    tatlers ridge nc
    put the truck on 8x8 wood blocks,...good trans jack!!! use the tie chains so trans dont fall!!!!!! good floor under jack!!! dont force nuttun...good luck...
  5. asavage1576
    asavage1576 Light Load Member
    62
    36
    Mar 18, 2013
    Dallas,Tx
    I have a plastic tray I mounted casters on. So I can lay my tools in there while under trucks. It's like a creeper for my tools. Keeps #### off the ground an out your way
    bigguns, xsetra and mgrantes Thank this.
  6. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    Removing is the easy part...I like threaded rods into bell housing to help guide when reinstalling. Don't skimp on clutch, or rear main while it's out out it back right. If you don't have a jack it can be done with pipe on the frame and a chain and roll it on back if you are jut changing clutch, but I don't advise that method, it's a have to case. Other than that it's more work than it is complicated for sure.
  7. 201
    201 Road Train Member
    12,641
    25,975
    Apr 16, 2014
    high plains colorado
    Unless your name is Arnold Swartzenegger, get some help, it weighs a ton. If you are putting a clutch in, go with a disc(s) with no springs (severe duty). It may be a little rougher engaging but it lasts a lot longer. I put 3 clutches in my trucks, and everytime those springs broke. Went with a severe duty, problem solved.
  8. carolinacrazyhorse
    35
    26
    Mar 13, 2014
    tatlers ridge nc
    put one them easy pedal pressure plate in it,..lot smoother engaging an last just as long as a severe duty one will...
  9. Tmtbob
    Tmtbob Medium Load Member
    303
    186
    Mar 3, 2014
    Oklahoma
    Make sure you put the plates in the right way if you install new or the plates in facing the same way they came out. I know a guy that burnt up a flywheel almost instantly cause he had them flipped
  10. BeenJammin
    BeenJammin Light Load Member
    256
    118
    Dec 17, 2013
    If it's got a nodal clutch housing with your rear engine mounts located there, and the mounting cap bolts are rust welded. That'll make you so happy, you could almost ####, at times.
  11. 201
    12,641
    25,975
    Apr 16, 2014
    Good time to replace the input shaft pilot bearing. They're cheap, and if it goes later on, guess what, out comes the trans again.:biggrin_2553:
