Transcraft or Fontaine
Discussion in 'Flatbed Trucking Forum' started by jchief, Aug 7, 2015.
  1. jchief
    jchief Bobtail Member
    47
    May 14, 2014
    Need some input quick.
    Looking at a new 53' combo flatbed, Cal legal, air ride. Want to purchase ASAP.
    Which one would you buy and why?
  3. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    NEITHER! is that quick enough?
  4. KenworthGuyNH
    KenworthGuyNH Road Train Member
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    Compare beam rating and bare weights. If you are comparing apples to apples go with whichever has the best price. It's all in what you are prepared to live with between those two; not that one is SO much better or worse than the other. Both will do the job.
    MJ1657 Thanks this.
  5. Espressolane
    18,264
    113,685
    first question, why are these the only choices you have?
    Some sort of lease or rent to own deal?
    Transcraft and Benson trailers are part of Wabash.
    Benson is the aluminum Transcraft is the steel. Having pulled these, I can say that I despised the transcraft. Floors are weak point on them, even with a coil package.
    AKA: transcrapt or transcracked both work
    Direct trailer is almost the same product, is slightly better and cheaper.
    I would buy one of them before a transcraft
    Fontaine is owned by Berkshire Hathaway. They have changed a lot over the last few years. Not familiar with the newest products, been a while since I had use of them. I know at that time the product seemed fairly good.
  6. If you just in a pinch. Look over both trailers for wear and tear, check tires installed and brake pads.
    Determine what applications you will use your trailer for choose accordingly.
    OP. Being sight unsceen I would pick the one with the best tires & less trailer damage.
    Good luck
    MJ1657 Thanks this.
  7. jchief
    47
    May 14, 2014
    Clarification:
    Looking at new trailers and I do oilfield mostly.
    I am in SW Louisiana and there is not a lot of options. I am trying to keep it about $30,000
  8. KenworthGuyNH
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    Why is CA legal a consideration for oilpatch work in your neck of the woods??
  9. jchief
    47
    May 14, 2014
    We do loads to CA several times a year.
    KenworthGuyNH Thanks this.
  10. Espressolane
    18,264
    113,685
    What do you gain by going 53 vs 48?
  11. jchief
    47
    May 14, 2014
    We have a customer that has 58' materials we haul from time to time.
    Any reason not to go to the 53?
