Transmission Change - Auto to Manual on 2005 Volvo
Discussion in 'Ask An Owner Operator' started by jaicartransport, Jun 11, 2024.
  1. jaicartransport
    jaicartransport Bobtail Member
    18
    18
    Oct 2, 2021
    Georgia
    Good day road warriors,
    Hoping to get some advice and or some help to find a resource. I got a 2005 Volvo 670 with a 3-pedal automatic. I want to change the transmission over to a 10-speed manual. Anyone ever done this, or got any references? I am in Georgia.
    2005 Volvo 670 with a Cummins CM870 - transmission RTO-16910C-AS2 10 S / K0326766
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,470
    6,507
    Aug 26, 2014
    I did that with a 2000 T800 last year. It is a farm sileage truck. It was breaking down every year. Corn stalks mud and water caused lots of problems.
    Purchased all the parts from Kerns in Atlanta. Drive shaft worked. Had to cut out the floor. They sent the sick boot and everything. Now it is a super truck. Cost about $4,000.00. Or they will do it for you.
    TH Evans LKQ in Athens way possibly be able to help you also.
  4. Lazer
    Lazer Road Train Member
    1,790
    2,850
    Jan 22, 2017
    Know a guy that has an IH Prostar, was one of the first couple years that auto-shift was an option. Transmission was the 6-10 Eaton Fuller Road Ranger. Pulled back the rubber flooring, and the ‘knock out template’ for the shift tower was there. Under the dash by the brake pedals most of the hangers were there for clutch and linkage. When to scrap yard got shift tower, and most of what they needed. Had to fabricate a few pieces, but he claimed wasn’t too bad. Unbolted the auto-shift box from the top of transmission, plugged the air lines running to it, bolted down the shift tower. Connected the clutch and linkage, and ready to roll. Claimed they never touched the ecm. At the time, being they had their own shop, it cost about $1,700.00.
  5. jaicartransport
    18
    18
    Oct 2, 2021
    Georgia
    That's awesome bro....I now exactly where Kerns is there in Ellenwood. I am only an hour south of Atlanta; and you say they can actually do the swap...will definitely inquire. Thanks
  6. jaicartransport
    18
    18
    Oct 2, 2021
    Georgia
    Wow.....I had a pm done and the tech did say that if I started to have problems with this auto-shift, to put a 10-speed manual it...he said that it was just air lines and should be pretty simple. So what you say seems to be accurate.
  7. BoxCarKidd
    4,470
    6,507
    Aug 26, 2014
    I thought the auto shift cases did not have a hole for the shuttle valve plunger in the left side of the case?
