Transmission clanging noise
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Yoster, Dec 17, 2022.
  1. Yoster
    Yoster Light Load Member
    59
    66
    May 16, 2011
    Fort Smith, Arkansas
    Hello, driving 10 speed Eaton Fuller manual. Recently started noticing a few times while accelerating and upshifting with heavy load that there will be a loud clang, and I can feel it on the shift stick. Sounds a bit unsettling, doesn't happen every day. Any ideas? Thanks.
  3. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I'm not an expert with Transmissions and I'm sure someone will come along that knows more than I do but my own opinion is it sounds like maybe your counter shafts are moving.
    If it were me and I had enough room, I think I would take the top cover off and inspect the forks and see how the gears look. This may be something that's just starting but I would imagine if the counter shaft(s) are moving around that's going to wear the teeth on your gears because they are coming out of alignment. I would reach down in there and see if you can feel any play in the shafts. If the play is bad enough that you can feel by hand that's a real problem.
    Okay that's my two cents let's see what the experts say.
    Yoster Thanks this.
  4. Dino soar
    4,815
    27,071
    Dec 8, 2017
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Transmission model number? Happens up shifting between which gears?
  6. MAMservices
    MAMservices Medium Load Member
    597
    4,387
    Aug 9, 2021
    In my opinion, I would first check engine/ transmission mounts, depending on the make and arrangements. If there is something moving around in the case that shouldn’t be, ie. counter shafts and such, it will eat itself pretty quickly, as that will put the shafts out of time, at minimum. If mounts, u-joints, yokes and such check out visually, I would drain the oil and see what kind of iron is on the plug for starters.
  7. Lyle H
    Lyle H Road Train Member
    1,292
    2,942
    Apr 16, 2014
    Sounds eerily similar to when the power divider went out on me once.
    haycarter Thanks this.
  8. Dino soar
    4,815
    27,071
    Dec 8, 2017
    One time my truck in certain gears I think it was about two gears I could feel something in the shifter and I began to wonder if my transmission was having a problem.
    So I went to buy a new set of tires and the old set had a little bit of River wear because they came off of another truck and I put new tires on it and it completely went away.
    So it certainly is possibly could be something behind the transmission I hadn't thought of that.
    We don't know what kind of truck you have but if the engine mounts are bad on a Freightliner or any of the regular trucks that don't have a pedal that go through the floor like the peterbilt, your clutch will feel funny.
    When you let the clutch out it will feel erratic because what's actually happening is instead of you engaging the drive shaft and it's smoothly turning, the engine is actually lifting before it moves the drive shaft and it's lifting your linkage and everything else.
    So in that case you would feel that in the clutch if it wasn't the Peterbilt type that goes through the floor.
  9. Yoster
    59
    66
    May 16, 2011
    Erm, not sure where I may find the model number. Would it be in the owner's manual? It's a 2014 Prostar. Happens while in gear and accelerating with a load and climbing gears. I usually float so I'm not using the clutch, although that likely also needs adjusting. It's only happened a few times. At first it was only in 3rd gear, but this last time it did it at 5th and 6th when I was trying to gain speed on a steep onramp. Thanks.
    Are you referring to the differential oil?
  10. Diesel Dave
    9,684
    32,936
    Jan 20, 2010
    Hesperia, Ca.
    I would check the u-joints, carrier bearing and the driveshaft(the slip thru part), they usually get missed on being lube.
  11. BoxCarKidd
    4,551
    6,641
    Aug 26, 2014
    Transmission should have a metal tag on it.
